Gimme WOK recommendations!
Gibson486
18,378
i used to have a wok on an electric. It was not a problem at all....It was not flat bottom either.
preslove
16,754
64
Howard
47,986
11
But but, which one?
Also, what technique do you use to season it?
Put a very thin layer of vegetable oil on it and bake it upside down in an oven or grill at 450F. Put a tray in the appropriate spot to catch any drippings. Take out the wok; if the layer feels gummy or sticky, it's not done. When it is done, you can reapply oil to thicken the layer for more durability and non-stickness.
Caution: wok will be fucking hot, and the oil will smoke a lot.
preslove
16,754
64
Yeah, I've seen that technique for all metal woks, but it doesn't seem to be a good idea for ones with wood/plastic handles...
Howard
47,986
11
Wrap the wood handles with cold water-soaked towels and then loosely wrap the towels with aluminum foil.
lxskllr
60,887
11,233
You don't really have to season it. It'll be sub optimal at first, but it'll season with use.
Howard
47,986
11
Huh, hadn't thought about that. This works?
Yes, the water absorbs significant amounts of heat energy and will prevent the wood from going over its boiling point (100C) until most of the water has evaporated. The foil insulates the towels to slow down this process.
