Gillette Mach3 or Gillette Fusion
Stunt
9,717
Never tried Fusion...for special events I use Mach 3, all other times it's electric (faster, less irritation, no consumables).
AnyMal
15,780
Mach 3 Turbo has much better and smoother moisturising strip. Lasts longer too.
mugs
48,920
46
Fusion, no doubt. Whether it's worth the money is up for some debate, but in the long run it's a relatively inconsequential amount of money.
Aharami
21,205
165
tried both as well as schick quattro. Fusion is dream to shave with. Glides over my face and leaves my face smooth as silk. Closest shave this side of a barber's straight edge blade.
Id say Fusion > Mach 3 >>> Quattro.
ScottFern
3,629
Gillette Fusion is terrible. The blades are so close together it gets clogged fast. My personal favorite is the Schick Quattro. Seems that 4 blades is good enough and they are spaced out enough where it doesn't get all clogged up.
mwtgg
10,491
The Quattro cut up my face and left it all irritated. I use the Fusion, myself, but if I don't have my Fusion available, the Mach3 is almost as good.
Gillette >>>>> Schick
Aharami
21,205
165
hah. the exact opposite happens to me, Quattro would get to clogged that id have to knock it against something to get all the hair out. With the fusion all I have to do is hold it under running water. But the mach 3 clogs the least though.
different strokes for different folks
Fenixgoon
33,443
13,062
the fusion gave me a closer shave than the mach3. also tried the schick quattro - it barely did anything the way the blades were designed. i still want to try and old school razor, though
silverpig
27,703
12
I like the shave from the mach 3 turbo better. The Fusion gets clogged too quickly, and it's hard to maneuver around the jaw line well. I love that single back blade though.
Feb 19, 2001
20,155
23
I've used both. I've also used the Quattro. I think I get used to the Fusion now. It's a little better. The fusion does get clogged easily, but I now feel it gets me a closer shave than the Mach 3. My only complaint is that it sometimes isnt the most comfortable, although it's nearly neck and neck with the Mach 3.
BTW, I have a Mach 3, M3 Turbo, Quattro, Quattro Titanium, Fusion Power.
