First off, I apologize for the rather dumb question. I've tried changing the values of Freq Latch and Strap but nothing seems to change the ratio as shown by CPU-Z.
I'm trying to find the highest oc on my Q9550 with my G.Skill DDR2 800. Right now, the G.Skills are doing DDR970 @ 1.9v and so far is passing tests.
I did 500fsb which pushes the RAM to 1000Mhz and maybe that's causing the hanging of XP once I start running Prime/OCCT/IBT.
So to take the G.Skills out of the equation, I was hoping to get it down to spec or even underclock it. But .................... no matter what I do to the settings in the BIOS, it doesn't change the ratio, it always shows up as 1:1. I'm sure I'm missing something and/or doing something wrong but I just don't know what.
Can anyone with the UD3* mobo please show your settings to force a different ratio for FSB
RAM so the RAM will run close to 800Mhz, considering my fsb is 500Mhz.
Thanks in advance.
Thanks in advance.
