imported_buddy
Guest
Hi, i recently got a k8nf-9 mobo, and im having a few weird probs with it.
I just cant get speedfan to load up, it installs fine, but when it loads for the first time it freezes, and i have to manully restart my pc to get rid of it.
I tried using /smbdebug in dosprompt, and it passed ok, and then loaded but said no chipset supported or something. I then tried /nosmartscan and it finally loaded ok, but im not sure if its reading right after all that, as i cant adjust fan speeds etc..
Also which mobo drivers do i use? i first installed the ones off the cd, then i installed the ones off the website(manully searching my mobo model, the versions were more uptodate), then i came across something on the website called gigabyte go? where it checks my system, and again it gave me different versions and drivers. So i installed those aswell(thinking that they're updates).
It installed marvell miniport driver(its in the add/remove list) and when i was installing the nforce drivers(iirc) it asked me if i wanted to install something with SW in it, i clicked ok(i never came across these two with the cd install).
Also in the task manager it has nvraidservice.exe, is this normal?
I havent set up raid or anything like that.
thanks for anyhelp, it would be greatly appreciated.
