Do any of you guys have the "DualBIOS/Q-flash utility" as an option in your bios menu? Seems I only have access to Q-flash when pressing F8, which is really annoying, since I corrupted my bios while flashing the F5 bios using @BIOS. Funny thing is that the bios partially works, but I get an "Unknown flash type" when it's trying to access my s-ata disk, so I need to have the WinXP cd in my cd-rom drive to get access. Another funny thing is that @BIOS said I successfully flashed my bios, but obivously that was not the case. So now I have a bios that's about 256Kb instead of 512Kb, and Q-flash refuses to let me reflash, because it thinks the correct bios size should be 256Kb. Same goes for dos-flashing and @BIOS flashing 🙁
With no access to the DualBIOS, I have no way of getting it reflashed. If there's no way to intentionally erase the BIOS, my only hope is that it's possible to get a new BIOS chip for this board. Do anyone know if the BIOS chip is permanently attached, or is it possible to remove it and install a new one?
EDIT: Okay, figured out what was wrong. For some reason I've flashed my card with the K8NS bios, and I have no idea how this was possible, since I know I downloaded the newest bios from the K8NS Pro section, which was F5 just a few days ago, and K8NS is already at F7. It pisses me off that it's possible to flash the card to a fully functional K8NS without DualBIOS, while it's not possible to flash the card back to K8NS Pro. I need some way to force a bios update, but it doesn't exist 🙁
