Hi guys,
I just purchased and received a Gigabyte BRIX GB-BXI3-4010 that I want to use as htpc with Windows 8.1.
I installed ram and mSata hardrive. Unit powers up but my tv screen stays desperately black. I tried the same cable, same TV same Input with a laptop and that works, so it must come from the Brix.
I tried to plug a keyboard and press F12 but nothing happens. A mouse that I plugged in usb also doesn't power on.
The blue led around the power button is on though... Any idea?
Something is faulty. Good luck trouble shooting it.
I built my PC and it wouldn't power on. I was an idiot and used a cable from my old power supply with my new one (was the only cable flat enough to fit in my SSD mounted behind my MOBO). Had to return the SSD and couldn't mount it behind the mobo due to power supply cords sucking.
It's a pain man, I wish you luck. The thing with DIY, you save money, but when you run into an issue it's NERVE RACKING.
Again, wish you luck man, I want one of these things bad I just have zero use for it 🙁. They're so cute/tiny though!
