Gigabyte 7Dxe post problem
DigitalCancer
3,726
I recently bought a Gigabyte 7Dxe, how would i go about testing this mobo to see if its bad or not. I've gotta Duron 1GHz, but i think its bad cause its chipped. When i go to boot it up, the cpu will hang after the mem count, i try to get to the bios screen and it hangs. Any suggestions? Should i buy a new mobo and cpu, or just the cpu?
imported_Phil
9,837
Sounds more like the RAM or an IDE device is faulty.
If the CPU was faulty then it probably wouldn't even start up.
DigitalCancer
3,726
hmm...well i've unplugged all IDE, even tried different sticks of ram...none of it worked
then i took the heatsink off the proc. and seen that it was scraping the top of it, the pin holders on the slot had been warn down by the h/s i guess, and he's flipped it around the wrong way, but the claws on this h/s scaps the proc, and i wiped off all the goo he had on the proc and seen the corner of the chip is chipped pretty good.
montag451
4,587
try the chip in another system, or, try another chip from another system in your rig
montag451
4,587
OR,
buy a pci POST CARD diagnostic thingey [technical term, of course], that will tell you how far the POST gets before failure
