Its immaterial when you're on a 1600x900 screen. The only time it may be relevant is if you move to a 2560x1600 screen or higher (multi-monitor).Only thing on the 680 that I am not sure is a limitation is the 256 bit memory bandwidth vs the 384 on the AMD.
Why are you going through this much trouble to help a thick head that don't attend to reason?
If he's fixed on any of those cards both are a bad pick based on his system and/or resolution.
Is this the card you're looking at? http://www.amazon.com/EVGA-GeForce-D...=cm_cr_pr_pb_t
For that amount of money, I would instead do this:
ASROCK Z77 Extreme4: http://www.amazon.com/LGA1155-CrossF...rds=asrock+z77 $135
Intel Core i5 3570K: http://www.amazon.com/Intel-Core-i5-...=ATVPDKIKX0DER - $210
2x 4GB Samsung DDR3 1600: http://www.newegg.com/Product/Produc...82E16820147225 $80
MSI Radeon HD7850 2GB: http://www.amazon.com/MSI-DisplayPor...=radeon+hd7850 $180
^ All of that will cost approximately the same as a single GTX680+ 4GB, but overall your system may be as much as twice as fast in the games you want to play. You could sell the HD7770, Q8200, motherboard and ram and make back around $300. With that difference you could get an HD7950 or even an HD7970 instead of the HD7850 to pair with the 3570K for the same amount of money you're willing to drop now.
Just go for a TITAN, since you obviously don't want to listen to reason from the people here on these forums.
BOOM:
http://www.microcenter.com/site/brands/intel-processor-bundles.aspx
You can actually get an i5-3570k + Z77 motherboard for around 2 hundy. That's a hell of a deal, your microcenter should have tons of stock as well. Not only is this cheaper than the 8350 combo, but will be a much better balanced, better performer. You can also use your existing DDR3-1333.
You can get the Z77A-G41 motherboard with an i5-3570k CPU for only 215$ at microcenter. That's a hell of a deal IMHO. And then you'll have enough money left over for a great GPU. It won't be a 680 or 7970, but trust me - you will be more than fine.
Okay, Another idea would be to get an AMD 4.0ghz 8350 Black Edition processor, this motherboard:
http://www.microcenter.com/product/398235/M5A97_R20_Socket_AM3_ATX_AMD_Motherboard
I could still utilize my 8GB of DDR3 1333 And to then get either a 7950 for $271 or a 660ti for $258. Any help would be greatly appreciated.
How does this sound.
Either 3570 i5 or AMD 8350 and motherboard for about $200-$240
Extra 8GB DDR3 RAM for $58 Maxing my system to 16GB of RAM
And either a 660ti for $238 or a 7870 LE for $249.
What would you go with out of that for best performance?
So, Is i5 faster than 8350 then overall?
And the 7870 is the xt version. Does that change anything? Will the 660ti or the 7870 xt which is much better than a regular 7870, be better?
