I have a 2 week old install of XP pro and I was installing Ulead movie factory and the system rebooted for some reason during install so now I cannot uninstall the program as I get a DLL error with a SP 2 error code to reinstall the program but I cannot install the program again as it says the previous install has to be removed. I had a restore point but the system will no go back to it like every time I try to use a restore point but I did a ghost image.
Here is the question I need help with
If I use the ghost 9.0 backup I will loose all my saved documents that were not there when I did the ghost backup right? So I need to backup my files again before I use the ghost image right.
