Miramonti
Gizmag link
youtube video
Props to Loz Blain for his grasp on this story. It looks like Durbin created an engineering masterpiece. Not bad for a plumber!
youtube video
Ready for a bit of a mental mechanical challenge? Try your hand at understanding how the D-Drive works. Steve Durnin's ingenious new gearbox design is infinitely variable - that is, with your motor running at a constant speed, the D-Drive transmission can smoothly transition from top gear all the way through neutral and into reverse. It doesn't need a clutch, it doesn't use any friction drive components, and the power is always transmitted through strong, reliable gear teeth. In fact, it's a potential revolution in transmission technology - it could be pretty much the holy grail of gearboxes... if only it wasn't so diabolically hard to explain. We flew to Australia's Gold Coast to take a close look at the D-Drive - and it looks to us like Durnin has pulled a rabbit out of his hat. Check out the video after the jump and see if you can work out if there's a catch.
