George Foreman Grill
Originally posted by: ttown
season = cook oil into it to make it non-stick. raw iron would stick like crazy.
250 degrees in the oven for a couple hours is probably enough
every half-hour or so you wipe the pan down with something like peanut oil and the pan soaks it up
at the end it's pretty much non-stick, but for cast-iron it's not dishwasher safe since iron rusts.
After cooking whatever, just heat the pan up and douse it with a couple tablespoons of water and quickly wipe/dry with a towel and you're done -- and then swipe it again with oil while it's still hot.
Seasoning at 250 degrees is the worst waste of time ever. If it's fresh iron (cleaned with lye or strong acid), the first layer should be applied at 350-400F, while subsequent layers can go on at the same or up to 450 if desired.
I had one awhile ago and even though I thoroughly cleaned it after every use, it developed a horrible greasy smell to it. It stunk up the house like crazy so I got rid of it and switched to iron skillets.
Bought a bunch of 'em about 6 years ago, gave most away as gifts but kept 2 for myself. The non-stick coating came off in places but I still use it. Works great for cooking chicken breasts, sausages, etc. (And putting a wet paper towel in right after cooking makes it easier to clean).
I have one, but it seems to make lousy dried out burgers.
Pork chops turn out better, but I can still do a better job with a frying pan.
I must admit that a George Foreman frying pan (with the grill grooves on it) can cook a mean steak, though.
I got one of those G5 swappable plate Foreman Grills as a wedding present this year. I finally bought some mix so I can make waffles. I'm stoked.
One of the worst-timed purchases I ever made.
I always wanted one but picked it up right before moving into a house and being taught by a friend how to grill outdoors. Now having an outdoor grill at my disposal, it would be no less than masochistic to go back to using a foreman grill.
I have one (old version/non removeable grill and rarely used) and now it would not turn on (no light) when I plug it in. Does anyone know how to fix it?
I use mine for Burgers or Grilled Cheese sandwiches. Steak/Chops are a little too difficult for it though, especially when Bones are involved.
Originally posted by: SlitheryDee
One of the best purchases I've ever made. It's like a microwave for grilling stuff.
Same here. I'd have gone hungry many a night without mine.
Yeah, I actually keep my pans on the bottom of my oven. Works well that way.
