Originally posted by: videoclone
If its running hot yes if its running cool no!
if it ever goes over 50c that too hot... if you you can stay under that at all time ... under load and idle then u should be fine ...
Case fans do the trick ! Chance's are your powersupply will die befor your CPU does when you overclockand by the time that happens you would have upgraded anways.
