sdifox
Originally posted by: Howard
Whoah, just found this thread.
Stop admiring the cast iron pans and you will see non cooking threads again.
It takes a while for the smell of a perfectly cooked ribeye to dissipate 😀
Originally posted by: YOyoYOhowsDAjello
If you're looking on shoponkyo, the $999 905 or $799 875 would be options with good conversion to HDMI.
Originally posted by: s44
Perhaps a section explaining HDMI audio vs. coax/optical, bitstreaming over HDMI 1.3 vs. LPCM over HDMI 1.1 vs. analog, and the lossless versions of DD/DTS vs. the standard ones would be useful? Or should that go in a separate post (Blu-Ray, your sound system, and you)?
The BIC H100 has been superseded by the F12, which lacks the nice glossy top and bottom but is cheaper (at or below $200 shipped).
Originally posted by: Patrick Wolf
Which of these setups would give the best bang for your buck? Price not so much the concern as sound quality. Also open to other options, but total cost should be at or below $550. Setup will be used for everything; movies, games, music: in that order. Side note: Current setup is the Klipsch Promedia 5.1 (non-ultra verson).
1. Quintet III + Dayton Basic Sub (8" or 10"). Quintet III can be had for about $400 on ebay + $100-$150 for the Sub: $500-$550 depending on Sub
2. Energy Take Classic 5.1: $400.
3. Not sure how good the included sub is on the Take Classic so I stumbled upon this option. Energy Take Classic 5.0 + Dayton Basic Sub (8" or 10"). $300-$350 depending on Sub.
Option 3 seems like an incredible bang for your buck, but I'm not sure how the Quintet III speakers compare to the Take Classic's.
Well, there are two subs claiming to derive from the H100. There's the F12, which is BIC's direct replacement. The Twister Group and Beach Audio had it for just under $200, but both are OOS right now. You can also get it through Amazon.Originally posted by: YOyoYOhowsDAjello
Do you have updated information I could use to put in the thread then? Is ebay still the best source for those?
