GeForce Video Problems - Screen Flashes Flickers Periodically
EglsFly
461
Myself and two of my friends all of us have GeForce cards, each different.
I just sold my Voodoo5 and bought a GeForce2 PRO,
One of my friends has a GeForce2 GTS
Another friend has a GeForce DDR
And we all have the same problems, the video will periodically flicker a distorted or messed up graphic within a blink of an eye.
It is mostly noticable sitting at the Unreal Tournament Menu Front-end screen. Kinda of looks like a tear in the graphic and it only lasts a split second.
We have tried various drivers, 6.31, 6.49, and 6.50.
None of these different versions of drivers has fixed this problem.
It sometimes also happens while I am playing Nascar4.
When I had my Voodoo5, I never saw problems like this.
Its got to be some NVidia chipset problem or driver issue.
Has anybody seen this before, is there a fix??? :disgust:
Help would greatly be appreciated!
Thanks,
Edward
RoboTECH
2,034
I get this same thing in UT D3d, 3dmark2001 at the beginning of the truck chase scene, and all throgh MBTR
try those games/demos if you don't mind.
I'm using 6.50, BTW
did your buddies have 3dfx cards in their systems prior?
did any of you do complete formats b4 installing the gf's?
EglsFly
461
I believe I may have fixed this problem, fired UT up, looks good so far (time will tell).
I changed the following:
>Disabled Video Bios Shadowing in the Mboard Bios
>Changed Refresh Rate from Optimal to 85Hz
>Direct3D Settings - Enabled alternate depth buffering technique
>Increased D3D PCI Texture Memory Size to 63MB
>Set Vertical sync mode to: Always off
