GeForce TI 4400 & DirectX issues
2cool4u
Hey,
I've been out of gaming a while and i just got my desktop rebuilt w/ all my old stuff and i tried to play a few games (Battlefield 2 demo, F.E.A.R demo) and htey are all giving me some sort of error relating to directx 9.0c. I ran a directx destroyer, and installed the 9.0c drivers but htey dont install right. In safe mode htey say 9.0c but on reg. boot it says 8.1 (because i rolled back to get rid of my old drivers). I wanted to know if this card is compatible w/ directx 9.0c because its only 2 years old but I should be able to upgrade to the directx 9.0c to play the games
Also, should I install the directx 9.0c, run dxdiag to make sure, then install the game to see if it works? Any help would be greatly appreciated
Thanks
heh you'l have no chance of running BF2
that game requires Pixel shaders 1.4 minimum and the GF4 Ti series only had 1.3
how ever FEAR has a DX8 mode, so u should be able to have a go at that, but you will need to have DX9.c for the runtimes. it should of just installed as an upgrade to DX8. DX9c even comes in the FEAR demo im sure.
the card is more than 2 years old tech wise. this card is pre R300 and thats 2yrs+ old
it should work though, it should be compatible and work with DX9 installed, even though the card doesnt have any DX9 level hardware at all
the games need it to run, because of the DX runtimes used i think
well your card doesnt support DX9 but its strange DX gives problems while installing. i suggest you get a 6600 or a X700Pro for about $100(or maybe lesser).
you can probably play BF2 at the lowest settings...640x7 and everything set to the lowest.(im not sure though!) games like HL2 should run well since it supports DX8.
Specs of my machine
AMD XP 2800 @ 2.1 Ghz
Asus a7n8x mobo
512 XMS @ 400 mhz
GeForce TI 4400
I'll look for the directx settings for old 8.0 ones. Hopefully i can get it to work. Also, any suggestions for a decent vid card for about 150 taht will play anything out there at decent settings?
It's hard to say, not to be mean. You need a descent upgrade :beer:
your options are:
Tight budget: 60-80 $$
6200
X600pro
budget: 80-120 $$
6600
X700pro
budget-budget-mid range: 130-160 $$
6800LE
6600GT
X800GT
budget-mid range 160-200 $$
6800
X800
mid high range 200-275 $$
6800 GT
X800 Pro, XL
High range, endless of wealth 300-380 $$
6800Ultra
X850XT / XTPE, X800XT/ XTPE
Originally posted by: 2cool4u
Specs of my machine
Asus a7n8x mobo
512 XMS @ 400 mhz
GeForce TI 4400
I would recommend these cards in order:
6600 GT
6800 LE (129.00 @ newegg, this card has potential to be unlocked w/ extra pipelines, etc)
6800 NU (vanilla version, if you can stretch you budget a bit, you can obtain this around 160 $)
X800 pro refurb (right @ shop.ati.com although it's refurbished, and cost 179.00, but it's best bang for the buck. Considering itself as a high range card, included with 3 years manufacturer's warranty)
As far I'm concern about your budget, stick with either 6600 GT, 6800LE (I recommend greatly), or even 6800 NU which is better
Thanks alot for your suggestions, it's been a LONG time since i put together a rig (as u can see my specs are outdate) so i'll def take this into consideration when i save up some money for a new rig.
dont get anything higher than a 6800NU. i suggest getting the 6600GT or X800(if there are any in AGP flavors).
