Novice here trying to do my first build. Pluged in my monitior to crank it up the first time and it just says no signal. Tried monitor on another computer and it is fine. Here are the specs
GeForce 7600 GT video card
MSI K9A2 Platinum mobo
Rosewill RX750-S-B ATX12V power supply
2 gigs ram
I do have it pluged into PCI Express slot. Fan does not come on - though not sure if it only does once it heats up.
The card is really tight length wise - it kinda pushed the case out a bit on the backside.?
Any advice is greatly appreciated!!
Thanks again
Kurto
2 gigs ram
Thanks again
Kurto
