- Jan 9, 2000
- 1,827
- 0
- 0
I need help...ever since 5.14s detonator some of the games (including Star Trek Voyager: EF, GP3 and 3dmark2000 demos) experience heavy polygon flashing. This is most noticable in OpenGL games (although it happens also in d3d). I tried pretty much every set of drivers (after 5.13s) out there and none have solved the problem.  As soon as I go back to 5.13 everything goes back to normal and flashing is gone. I tried comparing registry settings for 5.13 and 6.18, but there werer to many differences for me to positivly identify the suspect setting (if one existst of course) So to all of you driver and tweak gurus out there, is there anything I can do to fix this in the latest set drivers? or am I facing a painfull possibility of reinstalling the whole OS from scratch (which reminds me that I have ghost images from a few month s back so maybe it's not that bad, but I rather solve the problem in hand before going to such drastic measures)...system info if anyone cares...
PIII 800Mhz
MSI BX Master with latest BIOS (AGP 2x and aperature set to 64Megs)
192Megs PC133 SDRAM
Creative Labs Anihilator 2 GTS (not overclocked, actually i underclocked it for some of my test suspecting memory issues, but that theory has been proven wrong)
SB Live!
IWin Q500 with 300W power suply, case is very well ventilated and I even put card cooler underneath the GeForce to eliminate heat from the equation.
IDE DVDROM, CDRW, and HDD, etc, etc.
			PIII 800Mhz
192Megs PC133 SDRAM
SB Live!
