M mdrollas Senior member Apr 9, 2004 442 0 0 Sep 30, 2005 #1 I bought a 4025GZ from OD a few month ago. I worked fine until last night. The monitor just wont work. If I use the VGA connector, it works fine. Is it a bad panel/backlight? TIA
J Jiggz Diamond Member Mar 10, 2001 4,329 0 76 Sep 30, 2005 #3 So the LCD stopped working and then tried connecting a VGA and the VGA works? Or did you connect a VGA and then after the LCD won't work anymore?
