Ethanol has less energy per gallon, thus lower gas mileage. Just look at what people get with E85 vs. regular unleaded. But I doubt it would be very noticeable at 10% ethanol.
Don't get sucked in by the name. "E85" is NOT 85% Ethanol. It is 85% GASOLINE, and 15% Ethanol. In fact, until very recently, you could not buy "Gasohol" with over 10% Ethanol, even though many car makers label their engines compliant with "E85" fuels.
Could you tell the difference in gas mileage between 10% and 15% Ethanol? Yes, with careful documentation and a lot of study. But you'd have to quantify all the other influences on fuel mileage first, like the substantial effect of ambient temperature. Winter cold REALLY reduces mileage, and so do short trips vs. highway travel. I've tracked gas mileage every tankful on all my cars for many years. In any one car over a year, the result ranges quite a bit - the min is about 70% of "normal" max, and summer highway trips get 25% to 30% better than short trips around town. Against that kind of variation, measuring the mileage difference between 10% and 15% Ethanol in the gas is a challenge.
Anyway, I think ethanol has proven it's uselessness as an alternative fuel. It requires a high energy input to produce and a low energy output in use. It's really there to bolster the US corn industry.
Isn't E10 mandated by the province though? I don't think E85 is sold in Ontario. At least not in Toronto. I've never seen it. You can buy flex fuel vehicles though, but only through US automakers.
Cars run most efficiently when hot. Winter will give you worse mileage due to a cold engine, and increased time idling.
Too hot is too hot though, and you'll have preignition problems. That why the internal combustion engine is so limited with regards to efficiency.
It uses the gasoline to cool the engine.
You could lean out the mixture, and have a 50mpg car, but you'd burn up the engine within a few miles. That's also why you should use the lowest octane you can get away with. High octane fuel gives worse mileage because it burns cooler. It's used in high compression/turbo engines because it burns cooler(less efficiency) to prevent pinging.
You have nooooo idea. 3 years ago, all I knew is a carburetor is something in the engine that has something to do with mixing fuel and air. Now, I can stall out in the middle of the hill, a few hundred yards from the house, reach into my tool box (that's built into tractors), tear down, rebuild carburetor on the side of the road, cleaning the crap out of the needles, and get it restarted, all within about 5 minutes.
The Ethanol additive is not in there to replace the gasoline with an alternative fuel, it is there to oxygenate the fuel. Oxygenated fuel burns 'cleaner' so there are less Carbon Monoxide emissions. The additive helps the fuel burn more completely.
Remember when they were adding MTBE to the gas (late 80's, early 90's) as an additive? It didn't destroy soft parts in your carberator like Ethanol does, but it had a nasty habit of getting into the water supply through leaking gas tanks. Ethanol isn't quite as toxic as MTBE, so the refiners started using Ethanol as their only additive.
I agree that Ethanol is a worse (lower gas milage, corrosive to older vehicles) fuel than gasoline. If Ethanol didn't suck, then we would be have gas stations selling it for less than $1.00/gallon and driving the gasoline market into the dirt.
91 Octane at any Shell station has zero ethanol
Actually, while ethanol has been used since the 1980's to oxygenate gas and it has replaced MTBE, the concentrations to do so were nowhere near the 10% concentrations that are being used to replace that fraction of gasoline these days. Of course, one could say our pitiful attempt at using ethanol at 10% of fuel mixtures is just pandering to the corn producing states.....thank the previous administrations for that.
But yea, I can tell the difference between the 10% blend and pure gas. I get about ~37mpg with the 10%, and whenever I fill up with the pure gas, I get ~39mpg. Not a huge difference, but it's there.
No shit. This is why i buy gas from only 2 stations(Shell, Chevron) and then only the premium grade, its the only way to get no ethanol in your gas where i live.
I think the best way to put it is that engines run better when at their "proper operating temperature". If I remember correctly, there's also a factor of the type of oil that you have in your engine. If I remember correctly, the higher the weight, the worse it is in the cold weather. I was considering that this morning when it has been in the high 20s or low 30s for the past few days and my car's starting has seemed a bit rougher.
I really doubt that you're going to get warm enough for pre-ignition. That's usually a problem that you get from using too low of an octane rating for your gasoline ( the gasoline explodes under the pressure ) or an issue with things like carbon deposits on your cylinder walls.
I've never heard of this before. An engine is typically cooled using coolant (which is usually just water + anti-freeze).
If you lean out your mixture, your car should just see far reduced power (depending on how lean it is).
High octane gasoline is used in turbo-charged and high compression engines because higher octane gasoline will resist exploding under higher pressures. Both forced induction and high compression ratio engines will create higher cylinder pressures that necessitate gasoline that won't pre-ignite.
So many people are just spouting nonsense, incorrect information, numbers out of their ass, lies, etc in this thread. This just doesn't happen. Period. Ethanol content doesn't change your mileage noticeably until its over about 30%. Check your tires fool. Also check that you are actually pumping what fuel your car needs.My little 3 cylinder Chevrolet Metro gets 10% better gas mileage running pure gas versus that ethanol crap.
E10 (gasohol)
E10 (also called “gasohol”😉 is a blend of 10% ethanol and 90% gasoline sold in many parts of the country. All auto manufacturers approve the use of blends of 10% ethanol or less in their gasoline vehicles. However, vehicles will typically go 3–4% fewer miles per gallon on E10 than on straight gasoline.
Straight from the US DOE
E10 (gasohol)
E10 (also called gasohol) is a blend of 10% ethanol and 90% gasoline sold in many parts of the country. All auto manufacturers approve the use of blends of 10% ethanol or less in their gasoline vehicles. However, vehicles will typically go 34% fewer miles per gallon on E10 than on straight gasoline.
Yup, it gets a bit lower mileage but honestly the difference is so low that most people won't even notice it.
