Gas: Plus is much more than Regular but only slightly less than Premium?
Feb 4, 2009
35,862
17,406
*Warning I haven't read the whole thread.
Just use whatever octane your car manual says should be used. Higher octane gas does nothing in just about any car made after 1990.
I did once own a 76 Buick Regal that needed high octane gas to stop knocking (yes I changed the spark plugs & I think I did the wires too) however that was a carburetor car not fuel injected like all cars are today.
Above about Diesel you are correct you can't accidentally do it. I believe the nozzle is bigger too so it just won't fit in a non diesel car.
35,106
you cant accidently use diesel.
it has it's own handle/nozzle (green). so even if you accidently hit the diesel button, nothing happens since you have the gas nozzle (red) in your hand.
The diesel nozzle is larger in diameter as well so that it won't fit a gasoline fill neck.
LTC8K6
28,520
1,576
lxskllr
60,693
11,059
A little late I guess, but you should have checked the timing advance.
My truck recommends 91, but says 87 will work. I tried premium, and it didn't make a bit of difference. Maybe if I was towing in the mountains, but my usual load doesn't care what I use.
zerocool84
36,041
472
Not true to a certain degree. At my company, a newer driver put in diesel in one of your regular gas trucks. If there's a will, there's a way.
mxnerd
6,799
1,103
Pump half tank of regular & half tank of premium and you get a tank of plus gasoline that's fairly charged.
Feb 4, 2009
35,862
17,406
I'll confess a long time ago I had a honda nighthawk that I did some late night street racing with. Occasionally I'd go to a station that sold "racing fuel" that was super high octane, I can't remember the number but it was ridiculous. I'd put 2 gallons of it in before screwing around at night and I'll admit it felt smoother accelerating and felt faster. I doubt it made any real difference but two gallons who cares if it's twice the price.
13,988
From what I've heard when you go with premium you get a bit more energy out of it, so a tank will last you a bit longer. Whether or not that makes enough of a difference to justify it is another story though.
I always just put regular myself. I fill up maybe every 2-3 weeks give or take at about $50-$60 per tank so yeah gas prices are much higher than they were pre 9/11 but in the grand scheme of things it's not the cost that breaks the bank on it's own. It's just a piss off knowing that gas prices are just a huge political game and someone is getting rich off of that.
zerocool84
36,041
472
Your car has to specifically be able to utilize it so putting higher grade gas in a car that's not designed for it literally does nothing other than make your wallet lighter.
Meghan54
11,684
5,228
Octane won't make any difference in a vehicle that can't use it, unless it can. For instance, Honda only requires regular for their Ridgeline, but then in the owner's manual recommends using premium if you're going to tow.
The only difference I've ever noticed with gas is the difference between using el cheapo gas all the time vs. using only a name brand gas, or a top tier gas. Not such a difference that you'd notice in a tankful, but given time, there's a difference.
JEDI
29,391
2,738
genius!
but im thinking most people are sheep and won't even comprehend that possibility.
otherwise, gas stations would have done away with 89octane already
NutBucket
27,170
643
Must be a regional thing. In SoCal it's typically $0.10 between regular-mid and mid-premium.
John Connor
22,757
619
121
Imagine if all vehicles just used natural gas hybrids? They can do it, but the oil tycoons are making too much money.
pcgeek11
22,393
5,004
The diesel nozzle should be larger and not fit into a gasoline fill neck.
Carson Dyle
8,173
524
Where I am in Colorado, for years it was a flat 20 cents between each of the three grades. If you saw a sign advertising regular for $2.49, then 91 octane was almost sure to be $2.89. I've noticed that doesn't hold quite as true these days. The difference seems to be a bit more now.
This is a nice app for finding the best gas prices if you're not on E and looking for the nearest station. It's surprising how much difference there can be in local prices.
https://www.gasbuddy.com/
FirNaTine
639
185
I just don't understand why people buy a cat that needs a certain octane and put cheaper gas when the price difference is literally cents on the dollar. Plus if your car recommends premium, its probably a more expensive car anyways.
Where does your cat list it's recommended fuel grade? We rescued ours, and didn't get the original paperwork.
35,106
Cats run on premium, period. Whatever it is, if it isn't the most expensive option, the cat will drop dead.
