- Jan 16, 2001
- 31,528
- 3
- 76
This picture shows the regulator assembly for my gas grill; it's only available via mail order. Note how the part that attaches to the tank is permanently connected via compression fittings to the parts that go into each individual burner. It is one assembly and does not come apart.
The black knob that attaches to the gas tank has developed a leak and needs to be replaced. But I can't wait a week for a mail order item to arrive. I went to Home Depot and bought a replacement regulator, but the black hoses are terminated with screw-on fittings, which my grill obviously does not have.
What I'm planning on doing is splicing the new regulator into the existing hoses. I bought brass "barbed" couplers and worm clamps to facilitate that.
Is the pressure in a gas grill low enough that this will work? I.E. not leak? I'm planning on siliconing over splices as well. Thanks.
