Garmin or TomTom?
LS20
Banned
Jan 22, 2002
5,858
traffic features almost always (and i cant think of an exception) subscription based. usually 69$/yr
ViviTheMage
36,190
85
madgenius.com
Thats fine, I just have to find a unit that can do it well.
how are the C3x0 series? Are they capable of it?
JulesMaximus
74,459
854
I have a Garmin C320. I have all of SoCal and parts of Arizona and Nevada loaded in it.
I don't know about any traffic routing features...I don't think mine does that. It's very handy for finding places though.
ViviTheMage
36,190
85
madgenius.com
I know the C330 has preloaded US maps...I think I would get that for long road trips.
I cant tell which are capable of the traffic option.C340, C530, and C550 look like the only ones that can support the traffic option.
how are the navus compared to the C series?
ultimatebob
25,135
2,445
The Nuvi's are lighter and thinner, and the high-end ones have built in Bluetooth speaker phone and MP3 player.
They usually cost a lot more, though.
NoMoMoney
161
c550 and Nuvi 660 have the traffic receiver. It is built into the cigarette lighter adapter. Love them both. The 660 has a bigger screen and looks "sleeker". They both use the same GPS chipset. They updated things on the 660 like if you tap the screen while using the navigation screen it auto switches to scroll through the map. The 550 you have to click menu, view or whatever. I would recomend either to anyone. Both have bluetooth, the 660 has a built in FM transmitter taht sucks.
Other things about the 660
- The cig power cord plugs into the base, not the unit. It can plug into the unit as well. So you can take the unit off and leave the cord. The 550 connects to the unit.
- The suction cup on the 660 sucks, you have to use a little spit. The 550 is mUCH better. I switched them
- The 660 you can carry around in your pocket, very sheek
- The wider screen makes it a little easier to type in addresses and things
- The 660 volume control is in the menus whereas the 550 has a dial on the side for sound
- 3 months free for traffic on either to try them out.
- The estimated time is extremly accurate on both units. They have a much better way of calculating time of arrival. Most others (Tom Tom One and Delorme for PC) are horrible at estimating time. When there is traffic it even adds time for expected delays!
Ok, enough said. I like the Garmin's.
Fritzo
41,885
2,125
Also, not all cities have traffic broadcasts. You have to check to see if it's available in your area.
RossMAN
Grand Nagus
Feb 24, 2000
78,794
266
I've never used TomTom but we're very happy with our Garmin c320.
I've heard the new Garmin Nuvi's are wicked awesome.
akshatp
8,350
Ive got and only used TomTom GO910 and absolutely love it. Cant really compare to Magellan or Garmin.
