GAMING PC DONE (ALMOST)
abs0lut3
198
Originally posted by: Shizzle
I have 6 Dilemma's
This is what i ahve so far! my budget is $2,300
GAMING PC
AMD Athlon64 Venice 3500+ Socket 939Pin CPU Genuine Retail Box $299 www.msy.com.au
Epox 9NPA+ Ultra NF4U s939 NVIDIA nForce4 Ultra ATX AMD Motherboard $192 www.it-supermarket.com
256MB MSI Nvidia Geforce GF 7800GT DVI VIVO GF7800GT PCI-Express $540 www.msy.com.au
Seagate 250GB 8MB Cache SATA ATA100 HDD 7200rpm Hard Disk $172 www.msy.com.au
1 Gig Corsair DDR400 $152 www.msy.com.au
1.44mb Floppy Drive $15 www.msy.com.au
BenQ DW1640 DVD Dual Layer Burner $60 www.msy.com.au
17" Benq FP71G+S 8ms DVI LCD 7 days 0 bright dead pixel warranty $313 www.msy.com.au
Thermaltake Tsunami VA3000SWA $225 www.cworld.com.au
Or
ThermalTake Soprano VB1000SWS (SILVER) $169 www.vmcomputers.com.au
AT-SP500 Antec SmartPower 2.0 500W ATX Power Supply $110 www.hboutlet.com.au
Logitech keyboard + Optical Mouse $40 www.msy.com.au
Netgear WPN824 Rangemax Wireless 4 Router (108 Mbps MIMO Tech) $165 www.umart.net
Netgear WPN311RANGEMAX Wireless PCI Card 802.11G (108Mbps MIMO Tech) $99 www.umart.net
Plantronics Gamecom 1-PC Gaming Headset $48 www.ht.com.au
My 6 Dilemma's are ........
1) Go the 3500+ or downgrade to 3200+ (will be upgrading to dual core when a little cheaper)
2) a cheaper Keyboard and mouse ($40 for both i think is a bit steep)
3) Weather to get 2 Gig now or get 1 Gig now and Another 1 Gig later
4) atm the system cost is over my budget of $2,300
5) I believe i can get a cheaper quality Router as the signal is only going to be sent around 7 meters TOPS (downstairs)
6)WHICH CASE? i am leaning towards the Tsunami only because i heard its overall better!
Please Help....i just want to finnish researching and start Building.....thanks all
(barf) tell someone to fix that msy.com.au page. Yellow is giving me a headache!
First of all, I would skip out Antec power supply. Instead, I'd get the Silverstone they have on the following page and it's cheaper too while only losing about 40Watt.
Also, answering your question above are these:
1. If the price difference is quite abit ie 50 bucks cheaper if you go with 3200, go with the lower one. All in all, you are only losing 200mhz which isn't much really.
2. I would not go easy on keyboard and mouse. If you are going to spend so much time on your computer, mate, you might as well spend extra to feel more comfortable. Get no less than MX517 for gaming mouse or the newer G5/G7 series. Keyboard is all up to you. The ultimate keyboard is the G15. My cousin bought one and he loved it. I on the other hand got a awesome deal on the Microsoft Wireless Desktop Elite. I don't really game much and if I do, I have my joystick to cover it lolz.
3. It's all in the price, mate. If your budget allows you to buy two gig, get two gig. Otherwise one should be sufficient. Spend more on the more critical stuff such as power supply and video card.
4. Good gracious!
5. I don't really believe in the whole mumbo jumbo about MIMO stuff. I'll wait till they announce the real "N". Then I'll buy MIMO.
6. About the case, you really have to think about what you are going to do with your computer. Honestly, I like the Coolermaster Stacker 810. It has plenty of space and plenty of cooling whether I want a quiet system or an overclocking gaming system. It has an optional window on it (like 40US extra or something like that). Or You can wait until the CM Stacker 830 comes out next year (the one I really want).
Do some more research and see what you really want before make a decision.
Shizzle
272
Thanks for that....ill certanialy check these out! cheers
Any advice/opinion is helpfull so keep them comming!
abs0lut3
198
I wish you live in California right now, mate! We locally have this electronics store called Fry's Electronics and they sell this networking product brand called Airlink 101. They sell MIMO wireless routers for 29 US DOLLARS!! That's it...no more no less (just when they're on sale though) and the adapters were on sale for about 20 a piece as well.
here are the links for your to drool at:
*MIMO Wireless-G PCI or PC Card adapters
*Airlink 101 MIMO Wireless Router
But you have to remember something, mate. When you go full MIMO, everybody else in the house MUST run MIMO as well. Otherwise you must run regular G if you don't want people complaining around you.
I had to find that out the hardway...
