Gaming PC build advice? Help?!
mfenn
22,400
www.mfenn.com
What a difference!! It's like I've entered the world of modern computing all over again!!
I haven't bought any new games since 2006 because my old computer just wouldn't play them...or not well anyway...BF2 would chug along at 25-30 FPS if I had the eye candy turned up...now, I play it at over 10 FPS, not only with the full eye candy from the game, but with extra enhancements from the nVidia software. Games LOOK better, play better, and while I'm still bored with them after playing them for so many years, they're more fun and visually appealing than they've ever been.
Over 10 FPS? Ya don't say! :p
OP, you'll definitely be blown away by your new build.
mnewsham
14,539
428
The check came today, mnew. Just have to deposit it and place an order, so I'll say I'm ordering around Tuesday. Any updates or tweaks to this list? I'm very excited :)
Sandy bridge is back out, you need to decide if you want to try and build a sandy bridge build.
NomarFachix
117
What would the difference be in price, performance, difficulty in putting it together?
I have no real experience to speak of, so I'm going mainly off of your advice. I just want the best bang for my buck, the best gaming machine that I can put together for ~$1,000. I'm an open book, what do you think would be best?
mnewsham
14,539
428
If you can go to $1,100 you will increase cpu performance by a healthy 30% or more. If that won't sit with you let me know and il see later tonight if I can find deals and sales.
NomarFachix
117
If it pushed to 1.1k, how much would shipping estimate to? I don't terribly mind going 100$ higher, if it's a drastic difference. I'll just have to pick up an extra shift at work, lol.
mnewsham
14,539
428
Newegg ships stuff together, my last build total shipping was around 20 bucks.
mnewsham
14,539
428
When I get home I will start a build for you (im at work right now) do you need a monitor and OS?
mfenn
22,400
www.mfenn.com
mnewsham
14,539
428
CD/DVD
Case
HDD
Monitor
GPU
PSU
RAM
Motherboard
CPU/HSF
OS
Total: $1,048.14
NOTE: this computer can not Overclock because of the motherboard being H67 to Overclock you will need P67 (non are available on newegg at the moment but check back often as they will be soon) If you change to a P67 motherboard i would recommend this CPU combo instead.
I would also recommend the GIGABYTE UD3 P67 (revision B3) motherboard when it becomes available.
NomarFachix
117
How important (or, how much more efficiency) would I get via overclocking? Is it something I should wait for on the out of stock items?
Is it reasonable to hope that both would be restocked by Tuesday or Wednesday?
Sorry for the novice questions :(
mnewsham
14,539
428
It is possible in my opinion it is worth waiting for even if it isnt in stock, the i5-2500k OC's from 3.3ghz to 4.4Ghz with No problem.
NomarFachix
117
Alright, I'll wait on the other pieces I guess. Can I get an edited list with all of those preferred items? I'll keep checking them this week and place an order as soon as they're all available.
I know I'm probably a huge pain in the backside right now, but I really appreciate your help.
mnewsham
14,539
428
The list i have above except change the CPU combo to this one. and then change the motherboard to a P67 board costing around 130-140... you can post links in this thread if you find one.
mnewsham
14,539
428
The only other P67 available on newegg is $300+, so just more of a waiting game?
AFAIK that one is sold out too! All P67 boards are OOS, so you will need to wait, they were in stock last night so check back tomorrow for more.
NomarFachix
117
Alright, thanks! I'll check starting Tuesday, since that's why I'll technically be able to order. Don't want to get too excited when one gets in stock to see it back out when it comes through :)
I appreciate you!
NomarFachix
117
Ok so... as a complete noob making his first build, I'm honestly not sure that I'm going to be overclocking or even messing with that right now...
Knowing that, what would you suggest? I'm not sure how much that changes things, but I'm honestly not confident I'd want to get into overclocking until at least my second rig.
mnewsham
14,539
428
The stock i5-2500k is a very good CPU, keeping it at 3.3Ghz is fine it is PLENTY fast, that being said if in 3 years you feel you want a free "upgrade" then you can OC your I5 to 4.4Ghz EASILY! So i recommend staying with the current plan.
