I don't think it's a ridiculous statement to claim that web browsing would run smoother on Intel vs. AMD. Whether you'd notice it or not is a separate issue.
Yes, I am serious. A computer that runs faster than other computer is still faster regardless of whether or not you can perceive it. Computer science is an objective science.You cannot be serious. I've done "serious" browsing on craptops with horrible CPU's and still didn't have issues. So to say it would be "smoother" is completely moot if it's totally imperceptible.
If your talking about the time it takes from clicking on the browser icon to when it actually opens, then your talking about hard drive performance, not CPU's. And if your referring to how fast the performance is AFTER the browser is open, then your talking about how fast your internet is. Regardless it has no bearing on this discussion and is a ridiculous statement for arguing one CPU over another.
Actually, webpage rendering does need an at least semi-decent CPU. My parents still have a 1.6GHz Pentium 4 kicking around that they used as a daily driver until last year- and oh my goodness, that thing was a dog in internet browsing! As in completely unusably diabolically bad. They thought it was their internet connection being slow, but when I showed them that my laptop on a slow wifi connection loaded webpages far, far quicker than their PC on a 100MB/s ethernet connection, I think they realised it was time to put the P4 out to pasture!
The problem is, the i3-4130 trashes the 6300 in single-core performance, which means any non-game application like a web browser, etc, is going to run significantly smoother.
Frankly I cannot believe we are even discussing this D:.Hell, 85% of my web browsing runs smooth as butter on my 1GHz Brazos netbook. Saying that you would notice the difference between an i3 and the FX-6300 when browsing the net is laughable.
You're relying on some pretty strong hyperbole to make your argument. Web browsing is far more intensive than Notepad.Scientifically measurable, sure. But if it's totally useless in a real world situation I wouldn't factor it into my buying decisions at all.
I don't mind whether my CPU renders Notepad at 1000fps, or 20,000fps. One could literally be an order of magnitude slower than the other at that particular task, and it wouldn't bother me. It's only when one is noticeably slower than the other that I care in the slightest.
2Ghz Merom is rather slow, you gotta admit it. FX6300 on the other hand, even @ stock, is rather fast chip. It might not be as fast as 3Ghz IB in this particular "task", but I doubt one could notice any difference in web browsing performance between the two. Between FX6300 and Merom you would also notice similar difference. The thing is when you are past certain point and you have so much performance in the core it doesn't matter anymore if one or the other is 20 or even 30% faster when you cannot possibly feel that in real life usage scenarios.My Core i7-3517U (Ivy Bridge ULV, up to 3GHz Turbo) ultrabook is noticeably faster than my older 2007 Core 2 Duo 2GHz ''Merom'' laptop. Both running fast SSDs (Vertex 4 and Samsung 840), same browser.
It's becoming more intensive every year, too. There are some crazy flash games these days... I can't even run some of them on my girlfriend's 4(?) year laptop, because the framerates are unplayable.
If an i5 renders a modern webpage in half the time it took an FX, then it wouldn't be all that far-fetched to state that an i5 would be relevant for twice as long as the FX. Buying a video card that renders video games at 1200 FPS isn't a terrible idea, as it'd last you longer than one that renders at 60 FPS.
Don't you remember the testing that IDC did with the 8350 which showed that it sucked down close to 200W at stock speeds? Or the reviews elsewhere which showed FX cpus using more power than expected.
This is a failure to understand what TDP means. It does not mean "how much power the system, as a whole, pulls from the wall socket".
Anandtech's review found that the FX-8350 system had a total power consumption of 195.2 watts. So does that mean AMD is lying? After all, it's way more than the specified 125W TDP. But wait a minute - Intel's i7-3770K had a total system power consumption of 119.8 watts in that same chart, and its TDP is only 77W.
It's not hard to figure out why. First of all, even though this Anandtech review does not say what power supply was used, you'd need a very good one to get more than 90% efficiency at that rating. (And a really big PSU is less likely to get its highest efficiency numbers at relatively low draws like this.) So from the 195.2 watts of AC power being drawn from the wall, we get roughly 175 watts of DC power coming out of the PSU. And remember, that's for the whole system. The first page says they used a Radeon HD 5870 video card, and that could easily take up 20W-30W just displaying the Aero desktop while Prime95 or Linpack or whatever runs (we're assuming the "total system load" implies loading down the CPU, not the GPU). So we're down to about 145W. Then we've got the secondary DC-to-DC power conversion done by the motherboard. VRMs are not 100% efficient (why do you think they get so hot?) If VRM conversion if 85%-90% efficient, then we wind up with roughly 125W being delivered to the CPU itself, in line with spec.
Nicely said :thumbsup:This is a failure to understand what TDP means. It does not mean "how much power the system, as a whole, pulls from the wall socket".
