x1xBugsBunnyx1x
Banned
- Mar 29, 2002
- 286
- 0
- 0
had alot of good experience with the folks at visiontek, so im going to be buying one of there g4 ti4600 cards. lifetime warranty & only the fans went bad on there cards.. Good Luck
Originally posted by: Barrei
Try the 2920 drivers .
Originally posted by: BMW330ci
I received my replacement Gainward Ti4400 and everything seems to be running okay (no more artifacts) however, whenever I play Quake 3 for about 5 minutes, I get knocked out of the game with a Windows XP error stating their is something wrong with the quake.exe file. Using the 28.32 drivers and tried re-installing Quake 3 with no solution. When I play Return to Castle Wolfenstein, Windows XP kicks me out of the game with a blue screen that I can only see for a split second before rebooting automatically.
Anyone experience this same problem before?
I recommend you send it back to gainward. They turned it around inside of 24 hours upon receipt. They're apparently familiar with these problems so they've probably got a batch set aside that's a different revision or whatnot. If you return it to newegg you're likely to get a more dated version.Originally posted by: Wolfram
Add me to the list! Gainward Ti4400 with the same garbage output. Darn shame too, as I had heard so many good things about gainward. Now question is RMA to Gainward or go for something different from Newegg, if they will go for that.
Will have the system overclocked, anyone else know of any issues regarding this card in an overclocked system?
BMW, my system is an overclocked athlon with abit kr7-a raid, 2cas timing on 3cas ram. I'm overclocking the card as well to 300/650. It's been rock solid, I get really good framerates in RTCW 1600x1200. Keep at it, hopefully you can find something that works good for you.
Originally posted by: Satoshithegnome
I have the same problem as you!
I got my card, and all these blocks and windows came up and I don't know what to do. Took me forever to find this forum with this info, thought I got the one and a million.
I just bought a new comp cause I thought my old one couldn't support it but I guess it's just defective.
Hmmm, I want the VIVO so bad, but Gainward is the only seller of the VIVO GF 4's so I'm not sure what to do, because I definately don't want to get another defective card.
Any ideas?...
Thanks
