Originally posted by: zephyrprime
Originally posted by: yacoub
Ah okay so basically the top cards that kick butt just happen to ALSO have 512MB of ram, but the extra ram isn't what's making them kick butt?
It all depends on how much memory in textures you're consuming with your games. More ram doesn't automatically add speed; it just adds capacity. So if you were running some older game that only has 128MB of textures, the performance difference between boards with 512MB and 256MB of ram would be 0%.
The case where more ram is faster is if you start to need exceed that amount of video ram that you have. If you use a game that has 256mb texture sets and you use hi-res+high AA, the extra amount of ram needed for high AA could push you over the 256mb threshold and then you would have to rely on AGP memory. That's the situation where a 512mb card will beat a 256mb card even with a game than only uses 256mb texture sets. (of course, if you use a game with 512mb sets, then the 512mb card will have a huge advantage.)
