Fury cards will NOT have HDMI 2.0 outputs
JDG1980
1,663
570
It's been reported by TechPowerUp, and later confirmed by Legit Reviews, that the Fury cards will not include HDMI 2.0 support.
It's hard to overstate how serious a blunder this is, especially given the manner in which AMD is marketing these cards. The presentation on the 16th made a very good case for the Fury as a card for gaming on 4K TV sets. Both the "Project Quantum" exhibit and the Fury Nano announcement appear to be designed for set-top use; they make much more sense in that role than when paired with traditional monitors. The problem is that the overwhelming majority of 4K TV sets do not have DisplayPort inputs. Instead, the only way to get 4K @ 60 Hz with 4:4:4 color is to use HDMI 2.0.
This means that Project Quantum is pretty much meaningless. It's clearly intended to be hooked up to a TV, but it can't do 4K@60 on a TV. Likewise, the people who were discussing the use of Fury Nano as a hybrid HTPC/gaming card are now all going to be bitterly disappointed.
No, it doesn't matter that DisplayPort is a technically superior standard - go tell that to the TV manufacturers. No, pointing to adapters that don't exist yet is not a viable excuse either.
This is just another example of AMD having the worst marketing department ever. And an example of how, once a company starts pinching pennies, it's already circling the bowl.
iiiankiii
759
47
It's no excuse. They screwed up. But adapters will be release. That will mediate the problem. The End.
TemjinGold
3,050
65
Wait, how do we know the Nano will not support it? Maybe that's why it's being delayed a couple months?
happy medium
14,387
480
Good point we don't know.
My guess why its gonna come later.......?
Because they have to harvest cut down, low clocking, Fury pro chips.
The reason Fury pro releases on the 14th of July? They have to harvest cut down Fury X chips.
Edit: Quick question, does the chip/gpu decide whether you have HDMI 2.0 or is that a feature on the PCB? If its the chip, I think you wont see HDMI 2.0 on the Nano.
nvgpu
629
202
Nano uses the same Fiji GPU, Fiji does not support HDMI 2.0 at all as AMD's employee already said and verified by many sites.
Nano will not have HDMI 2.0, making it absolutely useless for 4K 60Hz UHD TVs unless you like gaming in 30Hz.
http://www.hdmi.org/press/press_release.aspx?prid=133
BERLIN, Germany - September 4, 2013 – IFA 2013 – HDMI Forum, Inc., a non-profit, mutual benefit corporation, today announced the release of Version 2.0 of the HDMI Specification.
No excuses really for AMD, HDMI 2.0 specification was released back in 2013. Nvidia delivered HDMI 2.0 last year and the rest of the GM20x series in 2015 top to bottom has HDMI 2.0.
happy medium
14,387
480
WOW thanks that was fast.
So its the GPU.
Looks like no Hdmi 2.0 on Nano to me.
dave1029
94
It's even worse than 30hz. It's limited to 24hz... Typical AMD... now I'm definitely not upset at buying my Titan X's before AMD released. They just can't get anything right. Ultimately that's why I switched from my R9 295x2.
gdansk
4,804
8,112
I knew it'd be something. For pinching pennies, it's not a bad area. Very few people have a 4K 60Hz television. (though the ones that do are among the most likely to buy a high end graphics card)
But it is of no issue to me as I'm using DisplayPort with my monitors.
rchunter
933
72
I'm more concerned about the lack of dvi than anything. I hope nvidia doesn't start cutting out dvi on future cards.
rchunter
933
72
In all fairness, they probably will as DVI is a dying standard. AMD is just slightly ahead of the curve with that.
Maybe so, if that happens the 980ti will be my last card for a good long while. I'm running a dl-dvi kvm so it's a lot harder for me to just change to display port.
Lalilulelo
34
Same. Not an issue for me, only a minority of the community will complain about no HDMI 2.0 , and no dvi support , oh well...I'll enjou my 144 hz :awe:
Feb 19, 2009
10,457
10
If you really intend to buy Fury X but wont due to lack of HDMI 2..
Otherwise you can keep on faux-raging.
Ofc, the logical pov is Fury X + active adapter cost = $$ and that has to be measured up against the competition which has native HDMI2.
n0x1ous
2,574
252
so is this adapter going to available next week? no? what about Korean dvi users?
Just admit that AMD is leaving a sizeable group of enthusiasts out in the cold with the I/O they are using on Fury X
10,457
10
DP to Dual-Link DVI adapters have been available for awhile now. The DP to HDMI 2 is something new.
Sure, the focus on DP on Fury X will reduce its compatibility, but it does support 2 active adapters. The adapter $ would have to be factored in for the total cost.
