- Nov 15, 2018
- 45
- 5
- 71
Hi All,
My furnace finally went out, specifically the fuel valve. It's an old unit, likely the original from when my condo was built, so over 30 years old, 72% efficiency. The replacement cost for this part was quoted at $650, which seems a bit steep for a handsized piece, but what do I know.
Condo is 3 stories, about 1500 sq ft. The current unit heated it sufficiently, though the degree difference was sometimes annoying. That is, if I set it to 70 it would go until almost 72 and wouldn't kick back on until it dropped to 68, but this may just be the older thermostat, I don't know.
I asked for some options for new furnaces. I thought about replacing the AC (also old, but works) + furnace + thermostat for rebates, but the max rebate seems a bit low in my area, only to the tune of ~$400.
So at this point I'm debating on whether to fix the existing furnace or get a new model. I'm not particular unhappy with the current unit other than it's a bit loud, but it's in the basement and I've dealt with it for a decade. My only concern with dropping this amount to fix it is what if/when something else in it breaks.
It's a Bryant unit and it's a good brand from what I know. A local well reviewed shop (that also installed this initially and maintenanced it before) is a Bryant distributor. They quoted both Bryant and Payne units. I got the following 3 estimates:
1) $2500
Bryant 310AAV024045
45k BTU, 80% AFUE
Should't be any existing structural changes with the above, just a simple replacement.
2) $3800 (I believe this includes the hole they'll have to add in for the PVC exhaust, which has been approved by my HOA)
40k BTU, 95.5% AFUE
Bryant 915SA30040S14
3) $6350
PG95XAT30040 Two Stage
40k/25k BTU, 95.5% AFUE
AC: PA14NC018
ECOBEE4 thermostat
Eligible for up to $425 rebate
I don't know anything about Payne though or if this is even needed at this point.
I have some reservations about the fancier multi stage units. My parents have complained about these "smarter" setups as not working too well compared to a simpler setup.
I'm also not sure if it makes sense to go for a high efficiency unit. Yes I will likely live in this condo for some years to come, but I really only run my furnace with regularity for 3 months, occasionally the other 1-2 (I'm in the Midwest). Most of my gas costs is in the unavoidable ~$25/month delivery charge which is year-round due to my gas water heater.
So with that I'm wondering about how long it would take to recoup the extra ~$1300 in terms of cost savings - sounds like several years.
I'm going to ask around some more and get a couple more estimates, but wanted to see if you all had any thoughts on:
1) Better to fix or go new since the current model is quite old?
2) Normal or high efficiency?
3) Get a new thermostat?
4) What kind of bargaining could I do? I know a while back there was some mail coming out about some place "giving away" furnaces if you just pay the labor costs; didn't go for it at the time because I didn't need it and it seemed scammy.
5) Think there will be anything around Black Friday?
Thanks for reading ... this was long.
Moved from OT.
admin allisolm
1) $2500
Bryant 310AAV024045
45k BTU, 80% AFUE
40k BTU, 95.5% AFUE
3) $6350
AC: PA14NC018
ECOBEE4 thermostat
Moved from OT.
admin allisolm
