HaxorNubcake
I had a hard time finding my exhausts...like I had to look under and behind the bumper (on my knees) to see them.
Anyways, Left Exhaust, Right Fuel door
Some BMWs did, so did the Jaguar E-type, and new Minis do. I'm sure there are some others out there too.Originally posted by: Howard
At least some Boxsters do.Originally posted by: ScottSwingleComputers
What kind of car has exhaust in the middle?Originally posted by: dirtboy
Fuel door is on the right, exhaust is in the middle.
ZV
ZV
Corvette most noteably.
ZV
But in my case, it is something you rarely see, a Crossfire.
Gas tank extends the full width of the car. The exhaust goes right under the tank in any front-engine car, regardless of the side the filler door is on.Originally posted by: d33pt
That makes sense if you think about it. They don't want to route the hot exhaust pipes next to the gas tank. Gas tank is usually close to where the fuel filler is.
ZV
Something would have to be very, very wrong for the exhaust pipe to be hot enough to ignite a gasoline fire that far back from the engine. Heck, in most cases even the headers don't get hot enough to ignite fuel.Originally posted by: nourdmrolNMT1
but however, if you think about it, it might go deeper than just the tank, yes the tank is above the exhaust (heat shield) however what happens if the filler bursts and is over the exhaust, then you have issues, but if its across from the exhaust its chances, although still there, are much less than if it were to be above the exhaust.Originally posted by: Zenmervolt
ZV
im not sure if its just tradition to do it this way, or what, its just a very interesting observation
ZV
ZV
New Mini-S. Don't think the non-s gets the center pipe.
