So I am currently working on the hand-me-down vehicle refernced in the title. It was given to me after sitting for several years with fuel in the system. Thus far, I have dropped the gas tank and had it vatted to clean it out and replaced the in-tank fuel pump and fuel relay. After reinstalling the tank and verifying that the fuel lines weren't blocked, I now get fuel all the way to the fuel distributor but none to the combustion chambers. I assume this is because the injectors are gunked up as fuel flows freely from the fuel distributor to the cold start valve. I have pulled the injectors and have a place located that will clean them, but before I go sinking much more cash into it, thought I would post here to see if anyone has any experience with this (or a similar) model. If there is something else likely to be problematic once the injectorsare cleaned, I would like to know so I can hopefully check it out now. So far I only have $300 or so in it, but if this is going to be a money pit, I will most likely end up parting it out or otherwise disposing of it.
