Kaido
I'm now torn between the two options:
Torched for insurance money.
Audi.
I almost spit out my drink man, it's too early for that hahaha
Audi.
Glad they are ok. Amazing how they can pinpoint the source of the fire even after the source exploded!
Audi.
If your jeep has a radio, it stays powered up to keep memory on the stations and time programmed in. There are ALWAYS certain circuits that are live when the key is off regardless of the vehicle.
Don't get me wrong, I'm a fan of old cars. But, to never park a newer car in the garage in case it could catch on fire seems a bit extreme to me. There are literally millions of new cars that get parked and don't catch fire. I understand 'playing it safe', but I only practice that up to a certain point (the point where I feel that something could happen not necessarily just unlikely it would happen)....
That's why I said I wouldn't park a newer car in my garage. The old ones are dead when they are cut off....completely.
Not if it doesn't have a hot wire run to it. Might have a small internal battery like a motherboard does for the presets, but there's not an "always on" wire run to it.
My 1994 cavalier had an "accessory" power and MOST cars do to keep power to the clock and other items. There's also memory in the PCM and other controllers. If you think your older vehicle is completely dead when you turn the key off, I urge you to go disconnect the ground lead and put an ammeter in there. I'd bet there are still a few things drawing power, even though they may be minimal.
Dude, I wired in in myself. I KNOW there's not a hot wire running to it. It's a Jeep CJ. There is no PCM. There is no clock. There was nothing in it from the factory that was powered up with the key off.
Trust me. It's not "on" at all.
Um. If we're talking about an aftermarket HU: you wired it wrong.
As I already noted not-very-far-at-all above your post, every aftermarket HU I've ever seen has two power supply wires, and will NOT hold settings without constant power. It doesn't mean the unit is 'on.' The switched power wire is what trigger it to power up.
I'm honestly not sure why anyone would argue about this at all. It's inconsequential...but if you wanna be fussy about it...yeah, there's a wire going to your radio that's on. Unless maybe you're talking about a radio old enough to be all-analog.
Seat heaters are controlled by a switch, relay and ignition switch. If the seat heaters were off, it would require at least 2 defects (very rare) for this to be the problem.
Apparently the Audi (I believe it was an A5) had automatic seat heaters. Never heard of automatic ones, mine have always required a button, but I guess these were triggered by temperature.
Depends on what you mean by automatic but if I remote start my GMC in cold weather the seat heaters come on to preheat things. I rather like it.Apparently the Audi (I believe it was an A5) had automatic seat heaters. Never heard of automatic ones, mine have always required a button, but I guess these were triggered by temperature.
