Freeware programs and applications (continuation)
aindejeje
Banned
Dec 2, 2007
convert internet networking to almost LAN networking
make online gaming works like multiplayer
recommended for Half-live or Dota players
can share files too..
Hamachi
Knowname
102
Dscaler
I did a search and didn't see it... I have NO clue what Dscaler 5.0 is, but Dscaler 4.0 is what should grab your attention if you have ANY intention of using a capture card to watch TV/ movies/ console gaming etc.. Dscaler has long been the best (IE CLEANEST) way to watch terrestrial TV on pc (through supported capture cards). It may be more agreeable to use an integrated pvr software for ease of use, but when you only want the BEST, get Dscaler 4.0
Windows Movie Maker 2.1 (for Windows XP)
For those that just want to throw together a bunch of clips for a quick home made DIY video, you MIGHT want to go the free route and try WMM (competitor to Adobe Premiere, moreso Premiere Elements though as I HIGHLY suggest against doing anything but the simplest slide shows/ wedding videos with WMM). Version 2.1 is officially downloadable, there is a version 2.6 or something that comes with Vista, won't work on XP, details are in it's Wikipedia artical. There is no download for it, as if you can use it... you should already have it (it comes with Vista). If you have to do anything more complicated with video, I suggest you spend the $40 on Magix Movie Editor
AMDZen
12,589
Has anyone tried the Online Armor Firewall
I had some problems with uTorrent using the Free version, but it hasn't been out very long and when they do work out the kinks it looks like this may give Comodo a run for its money
niall
153
Originally posted by: kmmatney
Great freeware drive imaging software:
DriveImageXML
DriveImageXML can "only" work in 2003, XP or Vista.
Does anyone know of a Ghost alternative for drive imaging which runs on Windows 2000?
Steve
15,946
11
I'm looking for recommendations on a good free file manager. I need to move a crapton of files from one PC to another over my LAN thru Windows shares, but I want to skip duplicate files (already existing at the target). Any suggestions? About to make a thread on this too in this forum.
p1tin
140
I would like to mention a FANTASTIC Freeware Disk Defragmentor ( already have mentioned in another thread):
Every now and then you come across a program that is so blindingly brilliant in its sheer simplicity that it takes you completely by surprise. JkDefrag v3.8 is one of those programs.
JK Defrag v3.8
A "complete" install with all the necessary utilities is available at link below.
I can thoroughly recommend this program, both from its simplicity and its flexibility.
Read the review if you want and then download from here:
http://www.openaccess.co.za/Bl...JkDefragExtraSetup.exe
or
http://rapidshare.com/files/38...JkDefragExtraSetup.exe
All credits go to the person who tested all the defrag software and his excellent reviews here:
http://donnedwards.openaccess....g-shootout-part-1.html
Excerpt from that site:
I'm glad I found this utility. I thought that Contig was the best freeware defrag program, and I still use it heavily, but JkDefrag is a masterpiece, and for a cash-strapped small business I have no problem installing it on all the workstations.
It is simplicity itself to use;
It is fast and effective;
The file placement algorithm is excellent; and
The screen saver option is logical and helpful.
The first good point is that it's free (released under the GNU General Public License), and it uses very little disk space. The entire download is a skimpy 320kb, including documentation. It doesn't have a setup program (yet), just a few simple instructions. I was so impressed with the program that I used Inno Setup to make a setup program which is listed on my "free stuff" page.
The second good point is that it has an intelligent screen saver. You can tell it to wait a predefined period (i.e. 6 hours) since the last defrag before trying again. The second brilliant feature is that once it has completed the defrag, you can tell it which other screen saver to run. So in my case I get it to run the Google Pack Screensaver, which is my favourite.
The third good point is that it has two defrag modes: fast or thorough. The default is fast, and it is as fast as Vopt8, and much faster than PerfectDisk. The thorough mode goes to the trouble of removing those tiny gaps between files that waste a lot of disk space, and took less time that PD normally takes. This is what DIRMS is supposed to do, and Vopt has a good go at tackling as well.
Another good point is the approach to temporary files. By default JkDefrag leaves 1% of the first part of your hard disk free, to be used by temporary files. The idea is that this would improve the performance of the system, but I haven't been able to measure it.
There are actually 4 programs in one: the graphical JkDefrag.exe, the command line JkDefragCmd.exe, the screen saver JkDefragScreenSaver.exe and JkDefragScreenSaver.scr. The command line version works great for me, because I can include it in a batch file I use to keep my hard drive in order.
When I ran my "torture test" involving the 4GB SQL file, JkDefrag performed well. The "fast" version decided that although one of the files was highly fragmented, all the pieces followed one another in a line, separated only by free disk space, so it left the file alone. The "thorough" option sorted the files out, and intelligently put the two main data files near the end of the disk.
There is no "interactive" mode where you can click on a disk cluster to see what files it contains. The graphical screen display uses screen pixels to represent the files. Unlike most other programs, this one uses the bottom left corner of the screen as the start of the hard drive. The colour scheme is also a little different to most, but the help file explains it all with elegant simplicity.
The only "missing" aspect of this program is that there are certain files it can't defragment because they are in use by the system. They recommend using Sysinternals PageDefrag v.32 to defragment these files, and the combination of the two works incredibly well. There is a third free utility, called NTREGOPT which can be run before rebooting, and this will compact the registry, after which PageDefrag sorts out any fragmentation.
Update: If imitation is the sincerest form of flattery, then Jeroen Kessels should feel flattered, because both Abexo Defragmenter Pro 5.0 and SpeedItUp FREE 4.0 clearly use the JkDefrag code, without acknowledging copyright or conforming to the GPL license.
gba
833
Best free VPN?
I would like a VPN for Windows 2000 that allows me to access my home PC from my laptop as though I was sitting in front of it. I have heard that LogMeIn Hamachi and OpenVPN were good solutions. Can anybody chime in?
thanks.
p1tin
140
I am using LogmeIn ( free service Only). It is good.
Free service of Logmein means you can only remote into the pc and operate it as if you were in front of it. - This is all I need so I am satisfied with the free service of Logme in.
I have been using it for about a year. It is a good, decent service.
gba
833
Originally posted by: solariusx3
Hi can anyone recommend a nice free sync and backup software? I need it to manage my upload file server
I have been using SyncBack Freeware V3.2.14 for about a year now to keep data on my desktop. laptop and external drives synched-up... it is decent.
"SyncBack is a flexible, and quite powerful backup and synchronization program that allows to to maintain backup copies of your files and folder, or to synchronize them, so that both locations always have a complete copy (e.g Laptop/PC). It offers different types of actions that let you choose how older and newer files are processed, which files should be excluded (by mask) and more. It offers standard file comparison based on the date and size, as well as optional MD5 checksum, which will detect even the slightest modifications to files. SyncBack also supports scheduled projects, FTP and zip compression of backups, as well as network login, simulation runs and more."
RU482
12,689
the OP mentioned a way to disable the popup that occurs when Anti-Vir auto updates. Anyone know how to disable it?
will889
1,463
I use the free (hard to believe a player this good is free) KMPlayer (software) to watch DVD's and have found it much better than VLC or GOM, or even the venerable Media Player Classic and yes even power dvd or windvd. It has a much better implementation of the AC3 filter and many more settings for the power user audio is absolutely superb one you tweak a few things in options.
Download
Forums
gba
833
I was *really* impressed with KMPlayer, which came highly recommended... It kept crashing on me, so I went back to Media Player Classic... I did not go to the forums looking for fixes, though., I suppose I will at some point, bc it is a cool player... It has really nice video controls... and a beautiful GUI
will889
1,463
I had that issue with the GOM player whereas the KMPlayer was flawless for me. MPC is good too but I found KM about 2x better on picture quality and sound quality, and it has a 3d spatial sound slider, and bass/treble sliders as well as a great boost option.
gba
833
Yeah... I will be giving it a second shot soon.. I will figure out what was causing my problem.
will889
1,463
^Probably a codec conflict if perhaps you have too may codec packages installed.
will889
1,463
ah yes I have K-lite mega.. so yeah... that could be it..
Probably. Just so you know it can replace winamp too, and if you enable the dscaler option in preferences (in the plugin section) it can replace your PVR software (if you have a TV card). Like I said the audio decoding and picture quality are just stunning. Every kind of audio tweak imaginable that the most powerful version of PowerDVD doesn't have.
gba
833
I am working on a new build, so I will give it a go on it... I will try it for both audio and video and leave Winamp and k-Lite/mpc off.. Again, I have not really done the research yet, but I am recalling reading that it comes with a nice load of codecs. Can you confirm this? Does it require anymore.. Seems like I should be taking the less-is-more approach, right?
will889
1,463
^Yes when it comes to codecs I think codec paks are generally a bad idea because over time eventually with new codecs installed and new players conflicts can arise. I hope it works out for your new build and KM works ok.
