FREE monitor test online (convergence, focus, color purity, dead pixel, CRT & LCD tests, etc)
Devistater
3,180
<< Thanks Devistater.
Was helpful for me. :)
<< I've used this site before, but never thought about posting it Great idea to make it a Hot Deal Devistater >>
Hey, no problem. I'm glad one of my first few hot deals that I posted is a good one that people appreciate :) I know that I appreciated the email from them telling me about this (a year or two ago I had signed up at thier website thinking I might get a monitor from them but I never did), so I figured some other people might like it also.
<< Ah man! This is pretty good. The only bad thing is it requires intenet explorer. You can download a test program from here that works with any platform that has a wish interpretor. >>
Hmm, what is a wish interpretor? I take it wish is something like java or whatever? Well anyway, I use IE, so it wasn't a problem for me, and probably most people do. But I thought it might be an issue for some people, so I did mention the requirements in the post :)
<< kewl. Now is there a way to save this >>
I dunno... you might be able to save the flash program, I've saved some flash programs before, but I seem to only be able to open them again if I make a html file with notepad and put a link to the file on my hard drive. Let us know how it goes :)
mrVW
992
stupid Flash thing doesn't work on my DualHead1280x1024 portrait setup :)
I have two Planar 17.4" (Thanks Anandtech + Dell) displays. One is on the DVI and one is analog... the DVI is a lot better.... especially if you need to use extension cables. I was able to find a Belkin 10' DVI cable... their is no signal problem on the DVI but going 10' (even high-quality cable) on the 15-pin VGA makes the signal way worse.
Tanner
7,391
stupid Flash thing doesn't work on my dualhead 1280x1024 portrait setup
U got a pic of that setup? I'd like to see it :D
I'm gonna try it I rekon...but I'm not sure if my fixed frequency SuperMatch 20-T can handle it...Just lastnight I turned it up to 1280x1024 for the first time and it's doing alright. Supposedly it's supposed to stay @ 1024x768. It's a fixed frequency monitor...so I hope that this doesn't hurt :D
Tanner
7,391
no WAY! :D I WON! WAHOOOOOOOOO! My 20year old monitor did GOOD! :D this thing ROX! :D I figured that component INPUT on a monitor had to be a good thing! :D It's got a SONY Trinitron tube....20 HUGE inches! :D
Kaervak
8,460
NEC MultiSync FE700. Everything looked perfect. Gotta love this monitor. :)
jamison
2,326
Sony G500 21''
The convergence really helped, my monitor seems much clearer now. Thanks!
nealr
771
Planar 17.4 (thanks anandtech & dell),
Envision 15(thanks anandtech & staples)
jimmyhaha
2,851
there are similar software available FREE from Nokia which is MORE comprehensive...
type "nokia monitor test" in yahoo
ftrainwill
64
hey hey, awesome, thanks for the heads up
I tested my 19" Sony Trinitron, with a built in 4 port USB hub
and tested my 17" KDS LCD, its awesome!, no dead pixels,
Thanx dude!
