Frame Rate Test Programs
WildThane
41
Can someone advise me on what program to run to test frame rate when playing games like BF3, COD, Crysis, will it appear on screen in game or will they just log to a file..?
BD231
10,568
138
In bf3 to see your frames u just hit " ~ " (located just before the number 1 at the top of your keyboard) then type " render.drawfps 1 ". Your fps will show in the top right hand corner. If you want to turn it off type " render.drawfps 0 ". The easy tool to use is a program called Fraps, although I hear it can hurt performance while in use. Its definitely easy to use though.
lavaheadache
6,893
14
To do it in crysis, hit the ~ key, then type r_displayinfo 1, enter
In cod I think it is ...... ~, then cg drawfps 1, enter. Not too sure cause its been so long.
Anyhow, fraps is a good program to use too.
