Found large heavy metal cylinder in garage - what is it?
Sukhoi
15,342
104
i believe that has +25 damage against robots and it's been modded with a stick for extra damage. you should equip it on strong when you assault the institute.
I think you got it.
Ballast is a reasonable idea, though 99.9% sure no riding mower for the yard given the small size. Maybe for a pickup truck or something. There are hundreds of wood stakes driven into the hillside behind the house for stairs, so pile driver could be right except the ends of the cylinder have no signs of impact. And yes, both ends are the same and seem to be some sort of sealing cap. Based on the amounts of surface rust they appear to be a different steel alloy than the sides.
vi edit
62,484
8,344
Homemade concrete screed? Ballast for a riding mower other lawn implement?
Is that a cap on the end? I think you should drill a hole in it; see what's in there.
Concrete screed was what I was thinking.
Sukhoi
15,342
104
You're right it does look the correct size to be a pallet roller.
I'm guessing is was a home-made surface smoother. It was dragged (using a light rope) over a soft surface (like recently-spread soil or sand) to make it smooth. Years ago on a new small rural golf course I saw such a tool provided at each hole. The "greens" were in fact sand, and you were supposed to lift your ball temporarily, drag this tool tool from there to the hole to make a smooth path, then replace your ball and make your putt.
Hmm yes, intriguing. The previous owners were very into their plants, with irrigation run all over the yard. Given that and the scary electrical wiring they seemed very "handy". The backyard has one of those patios with 3-4' square concrete sections separated by 2x4s. Wonder if they used this to smooth the gravel/sand under the concrete.
dank69
36,903
32,040
Can't see the pictars at work but from your description it sounds like a giant dildo.
flexy
8,464
155
This is interesting since the first idea I had when looking at the cylinder was "some type of green house heater" since they sort-of look like this.
Then again it it's not something you plug in, so I ditched the idea.
But now since you say that with the plants, I'd say it possibly served for flattening soil or something.
13,325
www.betteroff.ca
Hmm that looks similar to the rod sections they used in Chernobyl. But it's probably not from there as none survived in such a good condition, probably just a similar model reactor. They were fitted in bigger rods in a hexagon shape with the control rod in the middle then lowered into the reactor fluid (usually heavy water). It's what it looks like, a metal pipe with resin in it, the resin is the nuclear fuel, usually an uranium paste. Based on the rust this probably came from the spent fuel pool before it was stolen, back in the days workers would hand these out to friends and stuff, security was not as tight. On it's own it does not really create enough radiation to be harmful provided you don't stay near it for extended time every day (hours). I would not touch it though, it's still harmful to skin tissue at close range, mostly the exposed ends. Lot of nuclear workers back in the day got skin cancer at the palm of their hands before the dangers were really known as these were originally made that length so they can be comfortably carried that way. This is before they used cranes and stuff and mostly automated the shifting of fuel.
This arrangement was popular in the 60's to kill weeds, it was just pulled by a rope along the lawn at a slow pace and the next day all the weeds are dead. It was not very selective though, it often killed the lawn too, so it kinda stopped being used as DDT became a safer alternative. I just made all of this up.
Sukhoi
15,342
104
lol you had me going for a moment as a number of the retired professionals in this area worked at Lawrence Livermore National Lab.
Sukhoi
15,342
104
Update! It's ~35.5" long, 3.5" diameter. If I shake softly it I can tell that inside there appears to be a solid object of slightly lesser diameter that moves around. The length of the interior object seems similar as I do not notice it sliding from end to end when I tip the tube. Concrete does shrink as it cures. Though the cylinder definitely does not look like it was filled and sealed by a homeowner.
The outer diameter of the cylinder is reduced underneath where those metal straps were, and it is not as rusted there. I can't really tell if they are weld lines. The wood strip also has wear marks at the same spacing as the metal strips, which supports the idea of it being pulled around with ropes.
Now that I'm fairly confident that the interior is not pressurized or liquid I want to carefully cut an end open with a hack saw. Is this a bad idea? Wife is saying it's a bad idea.
DrDoug
3,580
1,629
It could be something explosive. The best way to check is to first try and smack it on one end with a big hammer.
If nothing happens, try the other end! :D
Sukhoi
15,342
104
I found the obituary of the former male owner of the house. He was a machinist and a WWII vet.
Would it be common for metals that are highly reactive with oxygen to be shipped in sealed steel cylinders? Or radioactive materials? It unfortunately does not weigh near enough to be gold.
31,961
Use a little hammer of the other end, for reasons.
gorcorps
aka Brandon
Jul 18, 2004
30,739
452
Reactive materials are typically shipped in glass. Not sure why something would be shipped in a giant metal tube that seems pretty thick.
BillGates
7,388
Big lawn? Possibly a homemade roller/striper that attached to the back of a riding mower to make stripes like a baseball/football field.
MongGrel
38,466
3,067
121
Bugs-gremlin.gif~c200
