Forum is being scraped again
Page 29 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
WelshBloke
33,399
11,551
I'm just on mobile. I've tried with a couple of browsers (to make sure it wasn't an ad block thing) and tried with and without a VPN and it's the same. No images and no uploads.
Forum isn't particularly slow for me though.
WelshBloke
33,399
11,551
Test.
WelshBloke
33,399
11,551
Images not working from external sources either.
(Although that could be me being a numpty)
13,979
Did the server run out of disk space? Sometimes it's easy to miss the obvious things lol. I would expect the whole DB to crash if that were the case but worth checking.
19,207
Or it has run into some file count limitation in the folder if all images are being stored in a single folder. I think you can't have a few million files in the same folder, at least on Windows. The fact that it's showing the filename only means that it can access the filename from the DB but not the actual storage drive. There won't be a crash if the DB and actual images are on different storage devices. At least MS SQL Server has some optimal cluster size requirement which is too big and wasteful to store smaller files so it wouldn't be wise to put other files on such a drive. I don't know about other DBs.
daveybrat
5,827
1,038
I had to hit refresh in my browser 3 times just to get the site loaded. Why is it still sooo slow?
BoomerD
66,585
14,989
Dammit...snail mode is back. Pages are taking as much as a minute to load.
I ran speedtest just to see if it was on my end...nope. 240/14.
Reactions: iRONic
