For VL! Intel G3920 review
escrow4
3,339
122
https://uk.hardware.info/reviews/67...cessor-review-skylake-for-a-trifle-conclusion
http://www.hardwaresecrets.com/celeron-g3900-cpu-review/
"The price difference between a Celeron and Pentium is exceptionally small this generation: for less than 10 bucks more than a G3920, you can get a Pentium G4400 which is 500 MHz (!) faster. That alone seems like a no-brainer to us, but you also get a faster IGP and another megabyte of enabled cache."
$20 difference here. I almost have the itch to build another shitbox. The G1820 (and the G1620) I had though was so meh. Still amazing Celeron is still kicking along decades later . . . . tempting.
VirtualLarry
56,587
10,225
If you're into overclocking, get a B150 K4/ Hyper board, and BCLK OC a G3900 up to 4.3+ Ghz.
Edit: Skylake really 'kicks', after 4+ Ghz.
HexiumVII
661
7
You don't even need to do that going from a Sandy Pentium to a Skylake Pentium is like lightning. You really can't tell a difference in basic web browsing and video watching.
VirtualLarry
56,587
10,225
I just installed a G3900 into an ASRock DeskMini mini-STX rig tonight. I had to split up the 2x8GB DDR4-2400 SO-DIMM kit, and put one 8GB into each DeskMini that I have, because I didn't buy a second RAM kit.
So, the first DeskMini has a G4400, and the second has the G3900. Both are hooked up to 40" 4K UHD TVs.
The G4400 is noticeably faster. Not sure if the onboard cache memory interacts with the iGPU at all. If it does, then perhaps the Pentium has more of an advantage in terms of real-world experience, than one might at first think.
