Yes this is good news, but I would like to add some more information.
As you all know, with the latest nvidia drivers (182.06) it allows you to possibly run 2 Smp's and a Gpu relatively without any problems. So, by adding a bit more voltage to your ICH, it helps with a second card, BUT both cards still have troubles with PPD production even with the adjustments. So, I did a bit of testing this weekend and this is what I found:
Tested with ( Main Rig )Q9450@ 3.4,
2 GTX 260/216
55nm @ 576/1512/999 (sync) on a EP45-DS3R. Vista 64.
Q6600@ 3.3,
2 GTX 260/216
65nm @ 576/1512/999 (sync) on a EP45-UD3P. XP 64.
Q6600@ 3.1,
1 GTX 260/216
55nm, GTX 260/
192 @ 576/1512/999 (sync) on a (Intel) XBX2. XP.
Main Rig seems to have the most difficulties (vista): Secondary, with only the basics installed, seem to be producing approx the same (XP). 2 Other rigs using Vista.
I looked at the Affinity in
Vista. At first it sets the Gpu FAH_core to all 4 Cpu cores. Once it started working, it sets the
Gpu FAH_core to only
1 Cpu core while the
Smp is set to each Cpu core ( if running 1 smp ). If running 2 Smp and Affinity changer is installed, the affinity will set the Smp to 2 Cpu cores each and Vista will still set the Gpu FAH_core to only 1 Cpu core. In
XP, it sets the Gpu FAH_core to
all Cpu cores. I removed NV_FAH_CPU_AFFINITY ( value 0 ) to see what happens and there is no change due to the latest nvidia drivers. I set the Affinity to all Cpu cores and
the PPD has improved a lot. But once the Wu has completed, it sets it back to 1 Cpu core, but only in
Vista.
F@H affinity changer is installed on all my rigs but if I am not mistaken, this only pertains to the Smp's ( if 2 are running ) and not Gpu. So vista has something to do with the affinity changing on the Gpu's. I uninstalled FAH Affinity changer and Vista still does the same thing. Since then, I reinstalled Affinity changer.
I am still trying to find out why Vista ( checked all rigs with Vista installed and found that they do the same) places the Gpu FAH_core to only one Cpu core as opposed to XP placing the Gpu FAH_core to all Cpu cores. Now since the latest drivers don't require much Cpu, 1 Cpu core should be sufficient. But when a Smp is running, it's better to have all Cpu cores for the Gpu FAH_core. It does affect the Cpu, but not much in PPD with 1 and or 2 Smp's running.
Take a look for yourselves and see what you can come up with. Any and all feedback is appreciated.
Edit: I was looking around and found
set affinity changer for Gpu and other things. I just installed it and testing it out. Will post back later with some news.
