for 25 years - zero cavities
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Originally posted by: Gibsons
bacteria is/are the plaque. the bacteria metabolize the sugar to produce acid.
I think there's a correlation between the dentists house payments and the number of cavities you have.
I agree with that correlation - for some dentists.
desk
1,124
Originally posted by: Doggiedog
Originally posted by: Papagayo
Do you drink bottle water all the time? The tap water is good for your teeth.. they have floride..
You are quite right.
My dentist was very happy about the bottled water craze since it contains no fluoride. :)
i use a PUR filter. wonder if that takes out the flouride?
Zim Hosein
Super Moderator | Elite Member
65,521
410
so, i've never had any trouble with my teeth for 25 years. i go to this dentist today (haven't been for three years) and he tells me i have 14 cavities :(
WTF? :confused:
Acanthus
19,915
ostif.org
Originally posted by: desk
Originally posted by: Acanthus
Im getting all 26 fixed this coming thursday. Im 22.
$11,000
Braces caused cavieites in every single one of my teeth along the gumline, i had them from age 13 to age 17 when i pulled them off with pliars. My dentist told me at that time that i had "calcification" along the gumline which was irreversible damage that would eventually decay.
why is your work costing so much?
even for the white fillings (which cost about 30% more then the silver ones), the dentist quoted around $180 per cavity. that would come to less the $5000. are you getting some other work done?
Umm its 8 root canales, 6 extractions, full veneers on the top and dozens of fillings. The decay is at the base of the teeth on the top and bottom right at the gumline, not in traditional places, this requires a LOT more work to deal with.
I got 2nd and 3rd opinions, the lowest quote was $8900 but ill go with my dentist as i trust him more.
desk
1,124
$11,000
oh...i thought you just had all cavities (i.e. just need fillings). yeh, i guess that kinda work can get pricey.
Eli
8
Originally posted by: Amused
A healthy diet is nearly irrelvant. How have you been taking care of your teeth? Do you floss daily? Do you brush 3 times a day?
Sugar being bad for teeth is an overhyped myth. ANY starchy foods can cause decay. In fact, bread is worse than sugar.
Also, you haven't been to a dentist in 3 years. That means you haven't had regular cleanings. That also means that mild decay that could have been merely sealed now must be filled.
I'm going to call you on that one. The last part anyway.
Sugars are directly available for the bacteria to metabolize. When they have direct access to simple sugars, there is a population and therefor acid production explosion.
Starches are bad, but they're not going to be as bad because it takes time for the starches to break down into simple sugars.
Sugar being bad for teeth is NOT an "overhyped myth". Where the fsck do you get off saying something like that? Even if starches were worse for your teeth than sugar, it still wouldn't be an "overhyped myth".
Amused
57,546
20,249
Sugar, especially sucrose (table sugar), appears to be required by the oral bacteria for the production of tooth decay. This finding has caused sugar to be widely blamed in the popular press as the primary cause of dental caries. However, caries incidence has recently declined in a time of increasing sugar intake.6 This has led to a reevaluation of caries causation, and sugar is now understood to be only one of the factors in the development of tooth decay.7 Nearly as important as the total amount of sugar intake seems to be the consistency of the sugary foods and the length of time they are in contact with the teeth. Dry and sticky foods tend to stay in contact longer, causing more plaque formation.8 Still, reduction of total dietary sugar is probably the most accepted dietary recommendation for the prevention of dental caries.9
Breads tend to stick on, and between the teeth far more than most other foods, and it the most eaten food among Americans.
So while sugar is essential to cavity formation, it alone is not the culprit.
I don't spount BS, Eli. I was going on recent findings I read about a few years ago.
Simply blaming sugar is simplistic.
http://www.eufic.org/gb/food/pag/food36/food363.htm
moshquerade
61,504
12
56
yeh, i agree there. the guy seemed almost happy, thats why i wanted to punch him. im definitely getting a second opinion before i go back.
get your xrays and get a second opinion, but don't be surprised with the 2nd dentist telling you that you have 14 cavities.
and i'll bet a lot of those cavities were in between your teeth because you don't floss regularly.
KingPhil
1,154
Originally posted by: bjc112
That's weird!
I am only 20 and didn't have cavities for all my life.. WEnt to the dentist about a year ago and had like 10!!!
The guy thought most of it was bad original fillings and such, I WAS PISSED!
Um........ if you haven't had cavities all your life, then how could the 10 be casued by "bad original fillings"??? That would mean you had cavities before?
Nutdotnet
7,721
I haven't been to a dentist in....12 years, and I'm only 24. :D
I'll be going within the next month or two (finally got insurance)...wonder how many cavities I will have...
Eli
8
Ahh, I understand.
I agree that simply blaming sugar is simplstic, I guess I just got the wrong impression from your comment.. It's not a myth that sugar causes tooth decay, it's a myth that ONLY sugar causes tooth decay... :)
Well, we all only know what we know.. I don't think anybody tries to spout BS on purpose... Well.. you know what I mean. ;)
Chadder007
7,560
$11,000
I'd sue the freaking brace manufacturer for that....
StageLeft
70,150
Teeth are disposable anyway. I didn't care much for mine as a kid and they look great now. All of my fillings are tooth-colored, so you can't see I have any. Every single mercury amalgam was removed (because they all started to rot underneath) and my teeth are nice and white from bleaching. If they all rot out I'll just have totally fake ones put in. A bad heart sucks. Bad liver sucks. Bad teeth who gives a crap, get fakes ones. Sure it's pricey but it's doable.
herkulease
3,923
I hope realize you're not being charged per cavity but rather per surface unless each cavity is on a different surface. I dunno your case specifics so I'll leave it at that. if you want to cut back on costs don't get composities for your posterier teeth. theres no point since when you smile no sees the back of your mouth anyhow.
also dentistry is a somewhat subjective field. you will find that dentist or other health providers hardly talk bad about each other when seeking a second opinion unless its a gross error. seriously it has to be really bad. Obviously some things are textbook cases while others are not. He or she could in their mind wanting cut off any future problems.
xrays don't show everything, taking your xrays to a new dentist will still cost you an exam cost anyhow as well they'll have to look plus they'll have to take xrays for their sake should issues arise.
moshquerade
61,504
12
56
dude, dentures SUCK! teeth are not disposable. don't buy into that. you get dentures and your jaw bone disingrates and your face changes. you lose vertical dimension which makes you look older and uglier.
not only that dentures don't always stay in that easily.
Kev
16,367
4
Your dentist might be a quack... never know.
I had one dentist tell me I had 4 cavities after 21 years of never having one, I said that's bullshit and asked for a 2nd opinion, and the other guy confirmed I was right. It was just markings from when I had my jaw wired shut.
Gulzakar
ummm, actually no...
have you seen the procedure for impants?
it's about a 9 months process...
forst evaluating you to see if oyu are a canidate...the older you get, the less likely.
false teeth are terrible...and bridges? that assumes you have healthy teeth.
no, bad teeth are not "easy" to deal with. I don't think people understand how important it is to take care of your teeth.
mwtgg
10,491
That's weird!
Read his post over again.
StageLeft
70,150
I'm talking full on teeth implants, drilled into the jaw/skull. That's how you do it.
SagaLore
24,036
21
the only thing that i can think that caused it was this annoying acid reflux that i have
Yep, that'll do it! Stomach acid will eat through metal.
If you can get your acid reflux under control, and brush after every meal - you might be able to avoid getting those small civities drilled and let the enamel heal on it's own. Then when the enamel gets hard enough, have the dentist seal all the weak spots in your teeth. That stuff will last quite awhile and prevent future cavities.
SagaLore
24,036
21
Originally posted by: Mo0o
14 cavities? is that like basically every tooth you can possible have a cavity for?
heh...not quite. you can have a cavity in each tooth (32?) and then a cavity between each tooth. so worst case is in the 60's.
My wife's teeth averages about 3 cavities per tooth.
