I just don't have the counter space for a rice cooker.
usually start the rice before I start cooking whatever I am going to put with it, chicken, beef, stir fry, whatever. It simmers on the back burner while I do my thing up front. After the meat and veggies are done, drain any excess water on rice and serve.
cleaning a simple non-stick sauce pan is easier than cleaning a rice cooker.
If someone wants to buy me an expensive Zhogoshiriu rice cooker I'll be glad to do a side by side comparison to the stove top method I use. 😀
I'll post back with an honest evaluation.
Okay. Let's start cooking at 5pm, leave the house for several hours and come back with some take out to use with the rice at 8pm and eat right away. Let's do a side by side comparison of how they turned out.
Rice cooker is preferable for me. I have the aroma type sold at costco.
I will say though, that mushy rice is still possible. I've found that having a bit less water than what is typically called for usually gives me the results I am after.
You do know rice cookers are non-stick now right? I just rinse mine with water, that's it. Takes me less than 30 seconds to wash mine.
Yep. If you get take out at a place that doesn't offer rice and you want rice with it and you want to eat it as soon as you get home then a rice cooker wins.
I'm sure this situation comes up but it would have to be someone that loves rice and that person will always have a rice cooker already. For everyone else they will either get rice with take out or it is just food they don't eat with rice.
😵 If I eat at 5PM why would I eat again several hours later?
Starting to cook rice at 5pm is not the same as eating. Oh wait, for you it is. :biggrin:
That's not the point. I would either have to:
A) Remove the pot from the cooker to clean in.
B) Wash it while still attached to the electrical components.
Neither is better than just taking that sauce pan I just did rice in and dropping it in the sink with the other pans.
Just too much counter space. I'd have to do rice everyday to justify a dedicated appliance.
What? Do you know how a rice cooker works? The pot is not attached to the rest of the cooker. You literally just have to lift it off, just like lifting off a pot from the stove.
every one I've seen is more like a crock pot, not a hot plate. And looking on amazon, that's the vast majority of them.
Restaurant rice sucks. Takeout rice even more so. The only thing takeout rice is good for is making fried rice day or two later after it's been sitting in the fridge.
Good sushi rice is the only exception to restaurant rice.
So do you make your own rice for take out? Do you own a rice cooker?
Yes, that's exactly what I have been referring to all along. It was my "A" option.
dafuq is so hard to understand?
I never said I had to break out the acetylene torch
How is taking the unattached pot out of the rick cooker and cleaning it harder than cleaning the pan/pot you used on the range? *completely confused*
Now I wonder if you have ever encountered a rice cooker IRL.every one I've seen is more like a crock pot, not a hot plate. And looking on amazon, that's the vast majority of them.
It's actually easier, since the rice bowl is less heavy (given the same capacity) and doesn't have a handle to get in the way.I was wondering the same thing? 😕
