Flooring for a basement?
rivan
9,677
Concrete slab. Something durable and won't harbor mold should it ever get wet. I'd like something less cold/hard than tile. Inexpensive is important. I also don't want a 'hollow' sounding/feeling flooring like some of them are.
Suggestions/experiences?
vi edit
62,484
8,345
Vinyl planks. Peel & stick 'em. Cheap, durable, water/mold resistant. Not as cold (but still kinda) as tile.
Other option is cork. More pricey, not as durable but much nicer under foot.
Sho'Nuff
6,211
121
First things first, find out if you have moisture wicking through the slab. Do that by taping a piece of tin foil to the floor and waiting a few days. If condensation forms between the foil and the slab, you need to install flooring that will breathe (i.e., NOT vinyl). Otherwise you will have a serious mold issue on your hands. Cheap carpet with a basement pad is probably your best option. Just did that in my basement and it came out great.
Imp
18,828
184
There was some big issue about vinyl and concrete I remember from my grad school classes.
It either had to do with water (vapor/water barrier) or the acid/base of cement. That was two years ago, so good luck!
Scarpozzi
26,392
1,780
Sno'Nuff said it. You can get moisture testing kits too to see how much water is coming through the slab. Concrete is pourous....There are ways to seal it, but a thin layer of sealant won't stop problems if there's a river running under the slab on a regular basis.
My recommendation is tile with radiant floor heating (if you're concerned with temp). Or cheaper, tile with throw rugs. (lightweight that can be washed often) Tile is most durable, can be inexpensive too. I recommend laying 16-18" tiles....they look good and per sq ft don't cost much more.
vi edit
62,484
8,345
Other option is sleepers + foam board + osb + any flooring type of your choice.
MiniDoom
5,305
i did acid stained concrete with epoxy seal in mine. very cheap, durable and easy.
Jimzz
4,399
190
Tile with a nice rug on it.
Rains hard or gets wet take the rug up and put back when dry.
14,092
I looked at VCT for my basement but was told any imperfection in the slab WILL pop out of the tile eventually. This probably goes for lot of similar products. So if your slab is not 100% smooth it's something to consider.
I'm working on my basement and I went with dricore, it's actually meant to be used as a sub floor product but I'll be using it as the main floor till I decide to later on put something on top. I'll probably stain and varnish it. Seen it done and it actually looks sharp.
http://www.homedepot.ca/product/2-f...ed-subfloor-panel-system-pallet-of-120/813185
lol just noticed it says "sold online only" not true... the store will have em. I'd hate to see the UPS shipping price for that LOL.
My basement slab is very rough and has lot of imperfections so I had to go with something that will completely cover that.
This is the crawlspace done:
dr150
6,570
24
This.
I know you don't want tile, OP, but porcelain tile is the best material.
It's attractive looking, the most durable, water resistant, best for resale house value, and can be had at a good price relative to vinyl-- just shop around as it's the install fee that'll hit you the most (regardless of material).
Just put cheap big rugs (i.e. Costco) over tile if you like to run barefoot.
Tile, tile, tile it......nothing beats it.
If you go ultra cheap, you will regret it on many fronts later down the road.....
FelixDeCat
31,301
2,791
shag
Sho'Nuff
6,211
121
Dricore is a good product. Unfortunately we could not use it in my basement because of serious ceiling height issues. We needed every inch of height because the distance from the slab to the bottom of the ceiling joists is only 6' 11". I'll post pics of what we did in a minute. Came out pretty good.
14,092
Yeah you do lose out about an inch or so, not counting whatever floor you would put on top.
Sho'Nuff
6,211
121
Here is what I just did in my basement. Built ins came out pretty good if you ask me. Flooring is basement pad +$1.50/sq. foot carpet.
iRONic
8,556
3,853
It seems nice, then I looked up. The ceiling... WTF? Did you just paint all the raw building materials and pipes white?
BurnItDwn
26,379
1,887
Part of my basement is Dricore + Vinyl tiles, with a rug, it would be very nice.
Part of my basement is cheap wet/dry carpet. It's not bad. (put in by previous owner)
Part of my basement is vinyl tiles direcctly on the concrete (bathroom)
Part of my basement is cheap rug over the concrete (it's not bad)
Part of my basement is Home theater riser made of 2x8 and 2x4, covered with an inch of OSB, covered with vinyl tiles, covered with rugs. It is very nice to walk on.
14,092
I'm actually debating on if I want to do that with my basement, just paint the ceiling all black. Redo all the visible electrical with BX or EMT to give it that industrial look.
iRONic
8,556
3,853
That's fine if you're going for that industrial look from the get go. You can carry that theme throughout the space or accent it.
Looking at Sho'Nuff's space, I don't get that impression. His decision of course...
Sho'Nuff
6,211
121
LOL. It looks better in person then it does in the pics.
The problem was that our basement ceiling was only 6' 11" from the slab. We couldn't dig any lower because the water table in my neighborhood is very high. To maximize the ceiling height, we installed a "drop ceiling" of sheetrock that was recessed about 2-3 inches up and between the ceiling joists. everything was painted white and the end result was pretty decent. Much better than it was, and I hardly notice it. Most folks that see it in person say that they like it (even the people I trust to give an honest opinion).
I'm not saying its the prettiest ceiling in the world. But when one is given lemons, make lemonade. IT was either do what we did or feel like the ceiling was coming down on us.
Also, we were not trying to go for the "industrial" look. Inspiration pics were:
