Fine, but you did not quote that post, and people generally assume that when you don't quote you're replying to the OP. Pretty ambiguous, there.It's clearly what I meant, look at the post I was replying to:
Unless the drains are clogged, there's no more standing water in the car.
He just needs to get the damp areas to dry out and he'll be fine, imo.
The O2 sensors were completely dry about 30 seconds after he started the car, I'd guess.
If he were going to have electrical problems from the water with ABS sensors, etc., he'd have seen them already.
His worry now is corrosion, and drying everything out well is the cure for that.
I drove to a carwash and they are vacuuming the water out right now. During the drive the airbag light stayed on and the cruise control lght flicked on and off constantly.
I am not a happy camper.
LTC pretty much everything in this post is wrong, now that we're all calling you out, lol...
You are calling me out after the situation has changed, though. Had I known that he still had standing water in the car, and had left it there, and that he was seeing electrical problems, I never would have said what I said.
Ah no... I called you out after everyone else called you out; before the OP came back and updated with electrical problems.
Really... just leave it. Maybe you posted without thinking first or something, I dunno. It doesn't really matter other than people should know they can't just towel up flooded water and expect no issues.
Wrong. Cars don't have floor drains, and they don't have "door drains" that are designed to empty out standing water in the event of a flood. They have holes and crap that are there as part of the process of making the door panel and etc, but in no way do the doors, body, trunk, etc have "drains". The only thing that really has a "drain" would be around the edges of some doors, on some cars - and sunroofs. Some cars have rubber plugs that can be pulled - but again, you cannot just towel up the water and forget about it.
Wrong. There will be mold/mildew no matter WHAT he does, even it's right after the flood happens. It is just about impossible to fully dry a car after it has been flooded as high as 20". To imply that he can just get the damp areas is again... Wrong.
Ok, technically yes, the 02 sensor itself is dry and fine. Again, it's not the connectors or sensors that are the problem, it's all of the standing water inside of his wiring looms and wire casing that CANNOT be dried out. It WILL cause corrosion over the next few days/weeks.
Wrong. In a flooded car it usually takes AT LEAST 24 hours for the problems to really show themselves. Again, these wiring looms are protected from splashing, heavy rain, brief puddles and designed to dry out in those situations. They do not hold out water in a flooded car.
Wrong. Honestly, corrosion (I'm assuming you mean body corrosion??) is the absolute least of the worried with a flooded car.
Alright now... Don't start fleabagging us 🙂
Um, every car out there most certainly DOES have door drains. And they are NOT part of the manufacturing process, they are there SPECIFICALLY to let water that passes by the belt moulding, mirror, vent glass, etc, out the bottom of the door.
Now, they might not be "designed" SPECIFICALLY to empty the door in case of a flood....then again, they are also going to be the spot where rising water enters the door in the first place.
But yes, all cars have door drains.
I think we're all confused and such. I say we blame fleabag and move on 🙂
OP... what year camry is this?
1999 Camry LE V6
And you have full coverage on it?
You also might want to talk to your apartment complex, their insurance should cover property damage due to flood.
My State Farm car insurance has comprehensive with a $500 deductible. I've never been in any kind of claims situation before. What are they likely to pay?
Um comprehensive? Nothing. It sounds like you don't have collision (full coverage) - maybe uninsured would cover it, I'm really not an insurance guy.
Comprehensive auto insurance covers theft, fire, vandalism, weather damage, riots, missiles, and other similar circumstances which may cause damage to a vehicle.
Comprehensive CoveragePays for damages to your vehicle that is not a result of a collision, such as theft of your car, vandalism, flooding, fire, or a broken windshield. However it will pay if you collide with an animal. Comprehensive Coverage will also pay substitute transportation expenses of up to $16 a day if your car is stolen. Payments will be made starting 48 hours after the theft is reported to us.
Well, the insurance report has been submitted. I dunno how that is going to screw up my resale value. I was hoping to trade in the car next year. 🙁
I covered that:
"The only thing that really has a "drain" would be around the edges of some doors, on some cars"
These drains aren't going to empty the water out of all the nooks and crannies inside his door panel. No way, no how. I'd bet even after 24hrs of hot weather there's still water pooled up in his firewall, trunk, door crevices/tracks, etc. You (or LTC?) were implying that car doors are somehow design to withstand FLOOD water, which is totally different from what the door drains are designed to drain.
Again, my bet is they total it.. In which case you'll get the market value of the car minus $500...
Market value before or after the flood? 😛
Bluebook says $6000 for my car in "excellent" condition. I would have said my car was in almost excellent condition before this.
EDIT: BTW, I just wanted to thank everybody who posted advice in this thread. Sorry, I've been kind of angry/sad/frustrated all day and didn't think of it earlier.
