Fixed: Yeah, not happy with this HD6950 (excessive heat with multimonitor problem)
Status
Not open for further replies.
WelshBloke
33,582
11,721
well if you can deal with medium graphics in most games at 1080p then a single 5770 seems to do that fine with multi monitor
I mean I'd use my 6950 to run my main monitor and the cheapest card I could find to run the other one(s). I'd get the performance of the 6850 for 3d stuff without the silly issues (hopefully, please don't tell me this is broke as well).
WelshBloke
33,582
11,721
Normal idle for dual monitors is 50C.....
I'd be worried, maybe you got a bad card. The RMA dept. is your friend.
I can just send it back for a refund (I'm in the UK) for any (or no reason) within 7 working days.
I think I'll do that and wait till they fix this issue.
I will be whining about it for a while though, nothing gets fixed otherwise. ():)
Edit : Have you got a link for dual monitor temps as all the ones I can find are all over the place.
mnewsham
14,539
428
the only thing i could see is driver issues with that
apoppin
34,890
alienbabeltech.com
You have to go forward into the future. Nvidia and AMD are working on it but there will always be higher clocks with a 2nd display.
Consider the improvement that Nvidia made with drivers from THG link:
According to Nvidia, it rectified the out-of-control increases that were being reported in the GeForce 256-series driver released earlier this year. So long as you're using two monitors with the same resolution and timing settings, you're supposedly safe. ...the temperature does increase by five degrees. Swapping over to a display running a different resolution, however, continues to have a profound effect on power and temperatures (Nvidia does not deny this). The jump from 192 W to 255 W and 45 degrees to 56 degrees is significant. The good news is that if you're using the same screen, the latest drivers minimize the impact of utilizing both of the GeForce GTX 580's display outputs.
WelshBloke
33,582
11,721
Consider the improvement that Nvidia made with GTX 580 over GTX 480 from THG link:
That doesn't look like going forward into the future, that looks like "lets half arse this and chuck something out that doesn't work properly" into the future.
apoppin
34,890
alienbabeltech.com
i don't agree considering the improvements both companies have made. If you have mis-matched LCDs, then you will have to wait - or put up with higher clocks.
The advantages of eyefinity or Surround vastly outweigh the negatives; same for multi-monitor. And i guess you could drive your second monitor off of IG or lesser video card if you did not want to deal with your HD 6950's spin up.
Since you have a hot running card, you ought to flash it into HD 6970
:biggrin:
Just kidding!
RavenSEAL
8,661
Well, it looks like the cards with single monitors are supposed to idle at around 43-46C, so with dual monitors, it should be about 5-7C hotter.
You said you were idling at 60 with duals right? Which display ports are you using?
WelshBloke
33,582
11,721
What improvements have they made?
Remember, consider my situation, mixed resolution monitors not in a 3d situation.
So where are the improvements? From where I'm sitting all I can see is a big step backwards. This used to work fine and now it doesn't.
To be completely unfair to you (partly because I'm, uncharacteristicly annoyed, partly because youre here and no other reviewers are) why didnt you make more of a fuss about this?. I buy cards partly based on what you say. You didn't mention this, and its not an obscure situation.
If some random game sent the cards temps soaring for no reason you'd report it. Its all very well to say the cards are great under very specific situations but you should point out that they are also pretty crappy under other, probably, more common ones.
Lonyo
21,938
People still didn't know about the dual monitors = higher clocks issue?
If you want, you could manually set it lower. They do it to make sure there are no display issues or something. You can set clocks lower manually if you desire, but like many have said, it's every card.
The reason it didn't used to happen much in the really olden days is because they didn't downclock in the first place. Hard to increase temps and power due to increased clocks over idle when there's only one clockspeed.
WelshBloke
33,582
11,721
Both dvi ports.
I do idle at 43-46c with one monitor.
Where does it say that there should only be a 5-6c increase?
There seems to be a hell of a lot of misinformation and confusion about this issue, seems like a good thing for someone to do an article about. :sneaky:
WelshBloke
33,582
11,721
No I cant, I'd be happy for you to link me some software to do it though.
apoppin
34,890
alienbabeltech.com
i am talking about the improvements that AMD and Nvidia have made to the drivers for eyefinity and Surround. It used to be far worse in the days of the GTX 480. They have expanded to 3 (plus in AMD's case) displays that can handle a field of view for gaming over 3 displays. Of course, this has somewhat left their productivity users out of luck (especially if you have mismatched LCDs).
i focus on *gaming performance* in my reviews. i only recently began using eyefinity and Surround myself and the issues do not bother me as much as they do you since i use it only for gaming.
Other sites that specialize in these kinds of things have made these issues known far and wide and AMD and Nvidia has been working to address them.
As far as 'temperatures soaring' .. i haven't found that. Perhaps your card is defective. It seems to run hotter than the usual HD 6950; it happens.
WelshBloke
33,582
11,721
]i am talking about the improvements that AMD and Nvidia have made to the drivers for eyefinity and Surround.[/B] It used to be far worse in the days of the GTX 480. They have expanded to 3 (plus in AMD's case) displays that can handle a field of view for gaming over 3 displays. Of course, this has somewhat left their productivity users out of luck (especially if you have mismatched LCDs).
Yeah but this thread and my issue isn't about that, and those improvements are irrelevant in this case.
Its fine that you focus on gaming in your reviews, that's why I bought my card as well. But the fact is I spend most of my time on the desktop and that's where this card (and apparently all modern gaming cards) are broken. I just think this should be pointed out, and if it was pointed out a bit more maybe it would get fixed quicker.
I'm not convinced my card is defective, it idles at a reasonable temp, if it ramps up the power with multimoniter then its going to get hotter or the fan is going to run faster and its going to get louder, both those are unacceptable to me.
And I dont think this issue is well known. Yes I know that the card wouldnt clock down as low but I didn't know it would be this bad, and looking at the posts in this thread neither did anyone else. And the only other guy here doing the same thing has the same experience (post 7).
Nox51
376
20
Can you clarify your position a bit for me from your previous post?
When you connect another monitor you don't expect the clocks to increase ( in addition to flow on effects from that such as temp, fan spin up and noise? ) or in this particular case you consider the clock increase to be too much, at unacceptable levels?
Thanks!
WelshBloke
33,582
11,721
Thanks!
I'm shocked that something I could do with an older card with no problems now causes my computer to pump out large amounts of heat and/or increase noise levels while essentially doing nothing.
I mean I wouldn't mind so much if I was asking it to work hard but I'm not.
We all gave the GTX480 stick for being hot but it seems we are happy to give cards a pass in this situation.
RavenSEAL
8,661
Welsh, just remember that the TJmax on these cards are 90-100C
Not justifying the high temps, but unless you're hitting 80-90C while playing games, i wouldn't be worried. By the way, how's your case airflow? room temp?
WelshBloke
33,582
11,721
Welsh, just remember that the TJmax on these cards are 100C.
Thats cool but I'm still not happy about my card idling at that temperature all the time for no reason.
I wasn't really worried about it melting, it makes my room hot, it makes the inside of my case hot, and it just looks like a half assed job of building a card.
Nox51
376
20
Thinking about the whole thing here maybe the issue was hidden by a number of factors in the past. Now I never ran multi monitor setups so I'm just speculating here. Maybe cards didn't have such aggressive down clocking profiles in and hooking up another monitor never made a difference since they were running closer to full throttle anyway. (I think someone mentioned this previously as well)
Also in the past the monitors used didn't have that big resolutions to add a lot of workload. Objectively speaking adding another monitor doubles the amount of work in all situations so I'd expect a change, more so a t large resolutions.
Regardless of my conjecture if you don't like the current setup and it's performance you're more than entitled to seek a change I reckon.
I'm keeping an eye on this since I was toying with the idea of another 1920 monitor. Wishful thinking really, I have better things to spend money on at the moment.
WelshBloke
33,582
11,721
But they didn't run at such stupidly high temperatures on the desktop either, which made it a non issue then.
My second monitor is only 10*12 (portrait). I wouldn't expect a card running a 30" monitor to kick out a noticeable amount of extra heat to one running a 17" one so I don't know why it should be an issue in this case.
Which would be fine if all the other cards didn't do it as well so there's no real choice, And I think they do it partly because they have been given a pass by reviewers, have you ever seen any big site kicking up a fuss about it?
mnewsham
14,539
428
i don't understand, i have two monitors (1920x1080 and 1600x900) and i idle at 43c (ambient temp is 22c) with a 5770 not a card from the "olden days" only last generation after all, is this luck or an isolated incident? I thought the multi monitor problems were already over.
imported_GrizzlyAdams
4
WelshBloke,
I believe the change from the old (working) generations to the new (busted) behavior with dual screens occurs because GPUs before the ATI x2xxx series used dedicated 2d hardware while everything is done in Shaders now. I may be wrong on the generation of hardware, but that'd be my conjecture for why there is such a massive change in temperature with the extra screen. [This is also partially why 2d acceleration took a step back with the advent of general purpose hardware, iirc]. Using the same monitors alleviates the issue by sharing resources (only need to generate 1 clock signal, probably share same space in memory, etc) if I'd have to guess.
mnewsham, if you upgraded your drivers to something recent you'd probably experience the same issues. I remember (poorly) the hubbub from this issue a couple months back and the fix came via drivers increasing the clock speed when the second monitor was attached. *Some* people had flickering with dual monitors (since the 5xxx series underclocked so aggressively on the desktop), causing them to whine about it, likewise causing AMD management to call in this simple fix.
This is all driver related, so find a utility and try playing with the 2d clocks until you find something suiting your needs. Hardly ideal, but the best I can do. Reminds me of the 'fix' for the bumpgate fiasco -- new drivers just ran the fan harder to minimize temperature fluctuations.
Obviously I'm going off memory here (which is deteriorating as of late), so take everything as 'generally correct, but probably wrong on the details'.
WelshBloke
33,582
11,721
WelshBloke,
Cheers for that, I cant find any software to let me downclock my card to any decent level, afterburner will take it down to 600/935 and its at 450/1250 anyway on the desktop.
If I could find the last generation of cards that didn't have this issue it would be cool.
RavenSEAL
8,661
Welsh, download MSI Afterburner 2.1 Beta 5 and set 2 profiles.
Leave it at stock for 3D Apps (Hit apply, save it as #1)
Then set the clock speed to 600MHZ and the memory speed to 935MHz (Hit apply, save as #2)
Go to settings>Profiles> Assign profile 1 to 3D, assign profile 2 to 2D> OK
See if that changes the temps.
Status
