steppinthrax
Well after changing the plugs checking vacuum lines carefully I decided to change the fuel filter. I removed the old fuel filter and turned it upside down. Black gas came out of the inlet part. I replaced it with a new filter. The vibrating tach needle that I had stoped immediatley and the car runs a little bit smoother. I guess the filter was restricted rather then clogged?
How often should you change the fuel filter. The car only had 30K on it. But it's a 99.
