I'm at my wits end here. First I need to explain the back story:
Back in August or September 2012 I purchased a 29-gallon fish tank from Petco. This isn't my first time with a fish tank, as I have been successfully running a small 10-gallon tank with two goldfish in it for nearly four years.
I set up the tank, began cycling it, and brought my water to Petco for testing. The guy said everything looked great but the pH was a little high, so he told me to use a product called API Proper pH 7.5. This was the biggest mistake I ever made in listening to him. The product ruined my tank completely, leaving it permanently cloudy. I had to drain the water and start over. Petco did replace my pump as it was ruined, but I kept the existing plastic plants, castle, and gravel. Here are a couple of pictures from the aftermath:
Well, the second mistake I made was after draining the tank I did not wash out the gravel. There was some of that Proper pH 7.5 salt-like stuff still in there, unbeknownst to me. I only found out after setting up the tank for the second time and having my water tested only to be told my ammonia levels were high. Also there was a milky-white substance that began to cover my castle. I took it out and scrubbed it down, vacuumed the gravel and replaced the castle. A few days later the substance came back. I drained it again and that's when I discovered more of the undissolved Proper pH 7.5 at the bottom. Here are some pictures of the first white jizz attack:
Now that you're up to speed, this is the latest development. Tired of having problems, I let the tank dry up completely as it sat there for months. Last Thursday I had the day off and decided to try again. This time I removed all the gravel and washed it. I cleaned out the inside of the tank with water and drained it. I replaced the gravel, put new water in, placed my plants and even exchanged the castle for a brand-new one. The tank has been running for almost a week and the white substance is back. This time it's not growing on the castle, but rather on random spots at the bottom where the gravel is. Here's a picture I just took today:
I've searched online for several hours and cannot identify with certainty what this stuff is, why it's growing, where it came from, and how to effectively get rid of it. This is extremely frustrating as I've been wanting to transfer my two goldfish from the old tank to this one. I know this is just a general forum but I figured there might be someone out there with some information I can use.
