fish oil
darkdiablo
212
i'm a beginner powerlifter, just wondering if anyone of you guys that lift weights take lots of fish oil? how does it benefit your body?
KoolDrew
10,226
7
A better question would be how doesn't it benefit your body. The benefits of fish oil range from help with fat loss, inflammation, cardiovascular health, depression, better brain function, etc. Just do a quick google search and you'll find a bunch of results.
As for amount, the minimum you should get is 6g. A standard capsule has 180mg EPA and 120mg DHA, so 6 caps would be 1020mg EPA and 720mg DHA for a total of 1.8g. I take 10g a day for a total of 3g combined DHA/EPA. There's no point in going over 10g because plasma saturation of DHA tops off at 1.2 grams a day (which is 10g). If you're using capsules with a different ratio of EPA/DHA, take however many pills will make you fall between 1.8-3g total and you should be good. There's no point in going over that and excessive amounts can impair immune function.
Mar 22, 2002
10,483
32
How do you afford taking so many? I take about 4 a day because it's pretty expensive. Got any online sources that could lighten the financial burden?
KoolDrew
10,226
7
I usually buy a bottle of Spring Valley fish oil from Walmart, which has 400 capsules and is rather cheap. Trueprotein.com also has a bottle of 1000 capsules for about $25 if you want to buy online.
crt1530
3,194
Costco or TrueProtein.com. Costco has a $2 coupon on fish oil once or twice per year. Every time I see that I make sure to stock up, because you can't find fish oil cheaper than that.
irishScott
21,562
Wouldn't enteric coating lessen the required dosage?
crt1530
3,194
Originally posted by: irishScottWouldn't enteric coating lessen the required dosage?
No. Enteric coating only prevents fish oil burps for people who have an issue with that. It has no effect on how much of the fatty acids are absorbed by your body.
darkdiablo
212
I have the NatureMade kind fish oil. I'm only taking 4 capsules per day. How many should I take to take advantage of the full benefits? I'm no doctor or chemist, so I've no idea. On the back it just says the amount of Omega-3 Fatty acid is about 720 mg per serving which is 2 capsules.
KoolDrew
10,226
7
I would suggest 5-8 capsules a day. I actually have a bottle of the same stuff right now and am taking 8 per day.
darkdiablo
212
Is there any risk of overdose if you take too much fish oil?
AdvancedRobotics
324
i actually started taking fish oil because i had read and my PT confirmed to me that it is a natural anti-inflammatory. i started taking it when i injured my shoulder last year. and i continue to take it now.
fish oil is a great supplement, and not expensive at all to boot!
Mar 22, 2002
10,483
32
Can you overdose on calories? Not really... They're just fats, not vitamins or anything.
Alone
7,490
By fish oil, do you all mean cod liver oil and such? Or is there a specific "fish oil" supplement.
KoolDrew
10,226
7
Research has shown the body is able to metabolize ALA (omega-3's) into EPA which is then metabolized to DHA. However, the end result is a small increase in EPA levels and a negligible increase in DHA levels. Considering EPA and DHA are what you're really after, not the ALA it is generally considered best to get your omega-3's from fish oils in either capsule or liquid form.
Here's the abstract if anybody's interested. I think I may have the full paper somewhere as well.
http://www.ncbi.nlm.nih.gov/sites/entrez
darkdiablo
212
I am beginning to love the taste of fish oil, just the fish smell makes me hungry.. mmm
Mar 22, 2002
10,483
32
Originally posted by: TechHead87
Where's a good place to get the liquid fish oil? I'm not good with pills...
I'm sure you could google around and see. The pills are really smooth and are probably the easiest pills for me to take even though they're medium-large in size. Have you ever tasted straight fish oil? Some people (most I've met) hate the flavor and that's why the pills are around.
KoolDrew
10,226
7
