First Water Cooling Project
H20Cool
Hey all. I've had this WC project completed now for a couple of months, but I didn't get the photos up until now. So here goes.
My XFX Geforce 6600GT with DD Maze 4 WB Installed
This is a photo I took just before installing the Videocard. Installation of the Maze4 went without a hitch and only took about fifteen minutes. Notice the ram sinks. I O/C the memory to 1200Mhz, so I figured they needed a little extra cooling, especially in the absence of a fan. The card runs great with this block. GPU idle temp is 33°C and the max. load temp after running 'rthdribl_1.2' for one hour is 39°C. So, suffice it to say, I'm quite impressed with this waterblock. Current config is OC'd to 600Mhz Core, 1200Mhz Mem.
System filled and bled.
Here's a shot of the fill and bleed line. I decided to place a shutoff valve at the end of the line for convenience. You can't see it in this pic but it's connected via a 5/8"ID brass T-fitting I bought at Home Depot. I had to heat up the end of my 1/2"ID tubing to get it on the T-fitting. The 5/8" fitting ended up working out well due to it's larger inner diameter, there is no flow restriction at all. In this picture you also see the Swiftech MCP650 pump located in the PSU area, as well as the Dtek Pro120 radiator located at the front of the case. The radiator assembly consists of two 120mm 70cfm Adda fans in a push-pull configuration with two custom fan shrouds to reduce the dead spot and to widen the airflow path to accomodate the 5 1/2" width of the rad. Cool, dust filtered air is taken in through the front of the case, blown through the radiator and then through the hard drives located behind it.
Ready to fire up!
Here is a shot I took just before I plugged everything back in.
The Flow pattern is as follows: PUMP --> RAD --> GPU --> NB --> CPU --> T-LINE --> PUMP
I used 5% Swiftech HydrX in distilled water as my coolant. Hence the lovely green 🙂
Powered Up for the first time.
This picture was taken with the flash enabled. Everything ran flawlessly, no problems 🙂
Flashless pic.
This is a shot I took with the flash disabled. Here, you get a more accurate respresentation of what it actually looks like. The blue glow from the rear exhaust fan is quite exagerated in this pic. Overall though, it came out a little darker than I would have liked. I'll try it again with some natural sunlight in the room.
Flashless closeup.
VL Systems L.I.S. II - System temperature display
I'm highly impressed with the Swiftech MCW6002-775 WB. 23*C idle @ 20*C ambient is all I could have asked for really. Case temp pretty much stayed the same as when I was on air cooling.
Shot from the front.
My first experience with water cooling has been an enjoyable and rewarding one to say the least. I got better temps than I expected, a quieter PC than expected and came across no problems with the installation whatsoever. It took me approx. 24 hours to complete it from start to finish including a 12 hour leak test.
Questions, comments welcome 🙂
wow diff case setup inside then ive usually seen
yeah, that's a lot of the reason for my choice of the Lian-Li V2000. Lots of room, and everything is sectioned off in it's own area.
I had to modify the original HDD cage. It had room for 12 HDDs, so I drilled out the rivets on one side and made room for the radiator assembly. Here are the pics:
Original HDD cage
Drilling out the rivets
Here's the piece that came off.
Finished and ready for radiator install.
I also had to move the original PSU location because my PSU wiring wasn't long enough to reach the Motherboard. That required drilling out six new holes for the PSU to mount properly. Here are the pics:
Here's the original PSU location.
Notice the ATX connector is not long enough to reach the mobo header. Out comes the drill, again 🙂
Modified PSU plate
Here is the PSU plate ready to be fastened back onto the case. I had to drill four new holes for the PSU to be oriented correctly so that it's fan was facing downward. I also had to drill through the two rivets holding the little L-support located under the PSU and flip the support to the other side of the plate and use screws to fasten it back on.
Finished
I also ended up removing the lower PSU support (at the bottom of the case) so it wouldn't get in the way of the pump.
So I had to perform a couple of minor mods on the V2000 case, but nothing too crazy. It was a bit of a pain in the ass having to modify a brand new case, but it just basically involved removing a few rivets and making a few small holes. The case still looks stock from the outside, and that's what was important to me. My requirements were that it had to contain all the water cooling gear and still look stock, and the V2000 lived up to that requirement.
Looks awesome. What about overclocking?
Thanks a lot for the compliments. It took a lot of money, sweat and tears (tears because of the money 🙂 !) to complete the project from start to finish, so I very much appreciate the possitive feedback.
I've got my XFX Geforce 6600GT OC'd to 600/1200 MHz from the stock 500/1000. It's solid, stable, and runs without a glitch. I managed to score 9630 3D marks in 3Dmark2003 with these settings.
I've also OC'd my 3.2GHz prescott proc to 3504 MHz (219 x 16) with a 876 MHz fsb and that's with 2 x 512MB Corsair ValueSelect DDR400. No voltage changes though. I'm really new to OCing so I haven't pushed it, but my system runs 100% stable at these settings and CPU core temp only rose 1*C to 24*C @ idle. I haven't tried to go any higher. Can anybody recommended settings to go higher? Maybe I'm limited by my memory? It's easy enough to change the fsb speed, but I also know that voltage has to be slightly raised at a certain point. I just didn't want to screw with something I don't know much about. Any recommendations are much appreciated.
You're almost definitely limited by the memory. You can raise the voltage of the RAM to, like 2.8 or 2.9. 2.9 is safe with 99% of RAM and you have good quality RAM (same as me). Once that stops working, use a memory divider. It would also save you a lot of time to lower the RAM speed a lot, like to a divider of 3/4, and find the max CPU speed when not limited by the RAM. Then its easy to choose a good divider.
VERY nice rig, real nice water setup ... i am looking to water cool soon, so expect some PM's from me ... 😉
Thanks again guys. I very much appreciate the positive feedback.
For those of you who asked about temps, they're listed in my sig, but I'll post'em up anyway 🙂
CPU: 23°C @ idle / 33°C @ full load (tested for one hour with "CPU burn-in")
GPU: 32°C @ idle / 39°C @ full load (tested for one hour with "3DMark2003" looped)
MB: 32°C @ idle / 36°C @ full load (after one hour of gaming, so not exactly scientific, buy hey it's real world 🙂 )
All tests were ran at an ambient room temperature of approx. 20°C
As for the Northbridge, I'm not sure because my mobo doesn't seem to have a sensor located there. Oh well, I'm sure it's a lot cooler with the WB, considering that prior to WCing, it was being passively cooled.
Musgrattios - thanks for the O/C tip, I'll give it a try.
killer rig! how much?
Thanks. Here's a break down of all the components I used to put this rig together, with the exception of the actual computer hardware itself. All prices denoted in CAD (Canadian) or USD (American) where applicable. I'll also provide links to where I purchased everything.
Lian Li PC-V2000 full tower case ---> $359.98 [CAD]
Swiftech MCW6002-775 CPU water block ---> $69.98 [CAD]
Danger Den Maze4 GPU water block ---> $43.98 [CAD]
Danger Den Maze4 chipset water block ---> $47.98 [CAD]
Swiftech MCP650 pump ---> $104.98 [CAD]
Clearflex 60 1/2" ID tubing X 15 feet ---> $37.35 [CAD]
Swiftech HydrX liquid coolant additive (2 oz bottle) ---> $3.50 [CAD]
Dtek Pro-120 high performance radiator ---> $34.99 [USD]
Pro-120 fan shroud kit X 2 ---> $19.98 [USD]
Other than that, I ordered a couple of 120mm fans for the radiator assembly, I bought a 5/8" ID (a little big, but I managed to get the tubing on with a little hot water) T-fitting from Home Depot for the fill and bleed line, and of course I got a 4 liter container of distilled water from my local drug store. Cost of these misc. items was around $50.00 [CAD].
So the grand total is approx: $786.46 [CAD] or $629.47 [USD] (current exchange rate)
All said and done with taxes and shipping, it basically cost me a thousand bucks. I didn't bother adding that to the breakdown as s/h and taxes vary considerably depending on where you're located.
You asked, how much? So there you go 🙂
