QuestionAsker
My new build powers on (fans spin, LEDs on) but no POST / no video output.
What I’ve tried / observed:
What else should I try to isolate the cause (BIOS, RAM compatibility, board issue, etc.)?
- System powers on normally (fans, LEDs).
- No signal on monitor (HDMI/DP).
- No POST screen, no beeps.
- Tried booting with Ryzen PRO 4750G, and then with Ryzen 5 3600 + GPU… still no POST screen or anything
- Motherboard: ASRock B550 Pro4
- CPU (primary): Ryzen PRO 4750G (used)
- One pin was bent when removed (now removed from system)
- CPU (test): Ryzen 5 3600 (used)
- GPU (with 3600): Gigabyte Radeon R9 390X
- RAM: 64 GB ECC UDIMM (2×32 GB Kingston KSM26ED8/32HC)
- PSU: Corsair RM850x
- Suspect BIOS incompatibility with 4750G or damaged CPU pin.
- Even with Ryzen 5 3600 + discrete GPU, still no POST.
- Test with a second (older) GPU
- Attempt to straighten the bent CPU pin on the 4750G (though it’s my first time doing that and I’m a bit nervous… it looks pretty bent)
