And 32nm Llano 9.7mm^2
Bobcat: (40nm): 4.6mm^2
Llano: 9.69mm^2
Westmere: 17.2mm^2
Sandy Bridge: 18.4mm^2
Bulldozer Module: 19.42mm^2
Oh well, should serve the laptop market quite well if it's at a competitive price...?
The CPU part was as hopeless as expected. No wonder AMD didnt want to talk about that.
performance increase was meh!
but the power consuption is insanely low for 4.2 GHz
resonant clock mesh is indeed awesome![]()
Is there a way to enable/disable it to compare the power consumption?
No ECC support = no revenue from me, try again AMD.
1) Can overclock to 4.4 ghz on the stock heatsink.
2) Is competitive with the i3 3220 at stock, should beat the i3 most of the time overclocked.
3) Has a far superior igp.
Its a great platform for your average gamer, someone who doesn't need top of the line hardware. OC the graphics a bit and enjoy games at 720p at playable framerates for the near future. When the igp starts lagging in games, switch it off, OC the CPU to 4.4+, and buy better graphics.
We’re power users, after all. We know how to cope with heat and noise; we can deal with a 100 W chip, even in an HTPC. But there’s no way to make the Core i3 look better unless you spring for an add-in card. AMD’s emphasis on balance makes the A10-5800K a better platform for more people than Intel’s closest competition.
That said, can somebody help me decide between the 5800K and 5700? Same GPU, nearly identical clock speed... but massively lower TDP for the 5700, all things considered.
If I buy the locked 5700, what am I losing? Because I definitely intend to overclock, but I don't know by how much, and will be pairing things with 2133MHz+ memory; Will I still be able to play around via FSB overclocking? And, more importantly, will I still be able to overclock the GPU?
